Get or Read Content Center Category
Guido.LangeTuchscherer
Message 1 of 9
Hello there,
having a part open and running a rule I check wether it is generated by the content center:
If doc.PropertySets.PropertySetExists("ContentCenter") = True
an alternative would be:
			'If Err.Number = 0 then it is a CC-part
			If Err.Number = 0 Then
				'If True then custom CC-part
				If iProperties.Value("ContentCenter", "IsCustomPart") = True Then
					MessageBox.Show("Custom CC-part")
				Else
					MessageBox.Show("Standard CC-part")
I would now like to check which category the part originates from, not the family, similar to the following i guess?
ThisApplication.ContentCenter.TreeViewTopNode.ChildNodes.Item("Profile")
How do i simply read the DisplayName of the category or likely?
Thanks for your help in advance.
Replies (8)
Message 2 of 9
FINET_Laurent
Dim sString As String = ThisApplication.ContentCenter.TreeViewTopNode.ChildNodes.Item(1).DisplayName
MsgBox(sString)
EDIT : Wait maybe i Understand your question wrong..
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
Message 3 of 9
@FINET_Laurent
Thanks for the quick Answer, getting closer 🙂
I need the information what ?? is for the current part:
ThisApplication.ContentCenter.TreeViewTopNode.ChildNodes.Item(??).DisplayName
Message 4 of 9
Anyone please:
Do I need to use this instead somehow?
ThisDoc.Document.PropertySets.Item(??)
Message 5 of 9
JhoelForshav
Hi @Guido.LangeTuchscherer
I just modified my code from here: https://forums.autodesk.com/t5/inventor-customization/extract-type-of-a-part-when-it-is-either-a-bol... a little and I think it's what you're looking for. Try this. Just run the code and pick your content member. It'll give you the first childnode to the top node that this member can be reached from.
Sub Main
	Dim oOcc As ComponentOccurrence = ThisApplication.CommandManager.Pick _
	(kAssemblyLeafOccurrenceFilter, "Pick occurrence")
	If oOcc.DefinitionDocumentType <> _
		kPartDocumentObject Then
		MsgBox("The occurrence is not a CC part.")
		Exit Sub
	Dim oOccDef As PartComponentDefinition = oOcc.Definition
	Dim oContentCenter As ContentCenter = ThisApplication.ContentCenter
	Dim propSet As PropertySet
	Try
	propSet = oOccDef.Document.PropertySets.Item("{B9600981-DEE8-4547-8D7C-E525B3A1727A}")
	Catch
		Exit Sub
	End Try
	Dim familyId As Inventor.Property = propSet.Item("FamilyId")
	Dim oContentFamily As ContentFamily = oContentCenter.GetContentObject("v3#" & familyId.Value & "#")
	Dim oContentNode As ContentTreeViewNode = oContentCenter.TreeViewTopNode
	For Each oNode As ContentTreeViewNode In oContentNode.ChildNodes
		If SearchNode(oNode, oContentFamily) Then MsgBox(oNode.DisplayName)
	Next
End Sub
Function SearchNode(oNode As ContentTreeViewNode, oFamily As ContentFamily) As Boolean
	Dim FamFound As Boolean = False
	For Each oFam As ContentFamily In oNode.Families
		If oFam Is oFamily
			FamFound = True
			Return True
	Next
	If oNode.ChildNodes.Count > 0
		For Each oChild As ContentTreeViewNode In oNode.ChildNodes
			If SearchNode(oChild, oFamily) = True
				FamFound = True
				Return True
		Next
	Return FamFound
End Function
Message 6 of 9
JhoelForshav
I just realized you wanted to run the rule from within the part. Not pick the part from an assembly.
Try this instead then 🙂
Sub Main
	Dim oDoc As PartDocument = ThisDoc.Document
	Try
		propSet = oDoc.PropertySets.Item("{B9600981-DEE8-4547-8D7C-E525B3A1727A}")
	Catch
		MsgBox("The Part is not a CC part.")
		Exit Sub
	End Try
	Dim CatName As String
			CatName = oNode.DisplayName
			Exit For
	Next
	'The node name is stored in variable CatName
	MsgBox(CatName)
End Sub
		If oFam Is oFamily
			FamFound = True
			Return True
	Next
				FamFound = True
				Return True
		Next
	Return FamFound
End Function
Message 7 of 9
@JhoelForshav
Thanks for the code, yes the result is what i need, just wondered if it could be done a bit lighter, as I really just need to know the Content Center Category or "TopContentTreeViewNode"?
Like this gives me back the Family Table:
MsgBox(ThisApplication.ActiveDocument.PropertySets.Item("{B9600981-DEE8-4547-8D7C-E525B3A1727A}")("Family").Value)
Is there not a way to read directly the Current Node, is the Content Center not saving these anywere in the file, so just the Familyname?
Message 8 of 9
JhoelForshav
From what I can tell there's no property in the document containing this information. That's why I wrote this code to use the family and search for it through the nodes in CC to determine its top node 🙂
Message 9 of 9
@JhoelForshav
Thanks for your help, since I startet using the content center from 2021 it is a bit slow, so I will probably add a Row in the content center families we use, simply containing the information, to make the read quicker.
But that is another matter 🙂
