Get model sketch in drawing view
Rene-J
Rene-J
Hi
Is it possible to set the (get model sketch) off a part
I have a sample it show how to set the sketch visibility.
But it only working if the (get model sketch) is set
I am using INV 2008.
Private Sub SketchVisibility()
' Get the active drawing document
Dim oDrawing As DrawingDocument
Set oDrawing = ThisApplication.ActiveDocument
' Get the referenced part document
Dim oPart As PartDocument
Set oPart = oDrawing.ReferencedFiles.Item(1)
Dim oDef As PartComponentDefinition
Set oDef = oPart.ComponentDefinition
' Get the first sketch in the part
Dim oSketch As Sketch
Set oSketch = oDef.Sketches.Item(1)
' Make the sketch visible in drawing
Call oDrawing.ActiveSheet.DrawingViews(1).SetVisibility(oSketch, True)
End Sub
René J
This macro seems to run fine on my machine (Inventor 2008) and makes the
sketch visible. Are you sure the sketch plane is parallel to the drawing
view?
Sanjay-
"René J <>" <=?UTF-8?Q?Ren=C3=A9_J_<>?=> wrote in message
news:5644674@discussion.autodesk.com...
Hi
End Sub
René J
Rene-J
I think you have misunderstand my question
I need to set or select the (Get model sketches).
before I can run my macro.
René J
Well, I didn't need to set the 'Get model sketches' before running the macro
(and it still worked fine). Why do you need to set that?
Sanjay-
news:5645341@discussion.autodesk.com...
René J
Rene-J
Sorry I have tested the macro and noting
happened, but now it work fine. I think it ways
the wrong sketch I was trying to set visibility.
Do you know how to set a sketch visibility in subassembly/subparts?
René J
You need to get the corresponding proxy object (PlanarSketchProxy) in the
context of the top level assembly and use that as input to the SetVisibility
method.
Sanjay-
news:5645375@discussion.autodesk.com...
René J
