Get mass properties from every model state
rafael.barata
rafael.barata
Hi guys,
Can you help me creating a rule to get physical properties from each model state in an assembly and place it in custom Iprops as:
Name -> "Modelstatename_Prop"
Value -> Prop value
Type -> Text or number
The objective is to get those props in an .idw note to specify a multi tool robot gripper 🙂
Properties are:
- Mass
- COG X coordinate
- COG Y coordinate
- COG Z coordinate
- COG Ixx
- COG Iyy
- COG Izz
WCrihfield
Hi @rafael.barata.  Here is something you can try out.
Sub Main
	If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
		MsgBox("An Assembly Document must be active for this rule to work. Exiting.", vbCritical, "")
		Exit Sub
	Dim oADoc As AssemblyDocument = ThisDoc.FactoryDocument
	Dim oMSs As ModelStates = oADoc.ComponentDefinition.ModelStates
	If oMSs.MemberEditScope <> MemberEditScopeEnum.kEditActiveMember Then
		oMSs.MemberEditScope = MemberEditScopeEnum.kEditActiveMember
	Dim oOrigMS As ModelState = oMSs.ActiveModelState
	For Each oMS As ModelState In oMSs
		oMS.Activate
		Dim oMSDoc As AssemblyDocument = oMS.FactoryDocument
		'oMSDoc.Rebuild2(True) 'helps ensure all updated, but may not be necessary (may take extra time)
		Dim oMP As MassProperties = oMSDoc.ComponentDefinition.MassProperties
		Dim oCOG As Inventor.Point = oMP.CenterOfMass
		Dim Ixx, Iyy, Izz, Ixy, Iyz, Ixz As Double
		oMP.XYZMomentsOfInertia(Ixx, Iyy, Izz, Ixy, Iyz, Ixz)
		TryCreateUpdateCustomProperty(oMSDoc, oMS.Name & "_Mass", oMP.Mass)
		TryCreateUpdateCustomProperty(oMSDoc, oMS.Name & "_COG X coordinate", oCOG.X)
		TryCreateUpdateCustomProperty(oMSDoc, oMS.Name & "_COG Y coordinate", oCOG.Y)
		TryCreateUpdateCustomProperty(oMSDoc, oMS.Name & "_COG Z coordinate", oCOG.Z)
		TryCreateUpdateCustomProperty(oMSDoc, oMS.Name & "_COG Ixx", Ixx)
		TryCreateUpdateCustomProperty(oMSDoc, oMS.Name & "_COG Iyy", Iyy)
		TryCreateUpdateCustomProperty(oMSDoc, oMS.Name & "_COG Izz", Izz)
	Next 'oMS
	oOrigMS.Activate
	If oADoc.RequiresUpdate Then oADoc.Update2(True)
End Sub
Sub TryCreateUpdateCustomProperty(oDoc As Inventor.Document, sPropName As String, _
oValue As Object, Optional sExpression As String = vbNullString)
	If IsNothing(oDoc) Or sPropName = "" Or oValue Is Nothing Then Exit Sub
	If oDoc.IsModifiable = False Then Exit Sub
	Dim oCProps As Inventor.PropertySet = oDoc.PropertySets.Item(4)
	Dim oCProp As Inventor.Property = Nothing
	Try
		oCProp = oCProps.Item(sPropName)
	Catch
		oCProp = oCProps.Add(oValue, sPropName)
	End Try
	If String.IsNullOrEmpty(sExpression) Then
		If oCProp.Value <> oValue Then oCProp.Value = oValue
	Else
		If oCProp.Expression <> sExpression Then oCProp.Expression = sExpression
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
rafael.barata
Excellent!!! There's just one little thing. It's converting the units of COGs coordinates and mass properties to cm when they're defined to mm as default.
WCrihfield
Hi @rafael.barata.  I forgot about units conversions.  Everything in Inventor having to do with measurements and units of measure, uses what is called 'database units' which is one specific set of all metric units for each measurement type (length, mass, temperature, time), and that is centimeters for length.  So most measurements you get from Inventor by code are in those database units by default, instead of in document units.  This situation has been a major pain for many years, but it seems to be the only way Autodesk can write the programming for all that numerical stuff and keep it straight.  Below is an altered version of the code that uses a built-in units conversion tool.
Sub Main
		Exit Sub
	Dim UOM As UnitsOfMeasure = oADoc.UnitsOfMeasure
	Dim oDocLengthUnits As UnitsTypeEnum = UOM.LengthUnits
	Dim oDBLengthUnits As UnitsTypeEnum = UnitsTypeEnum.kDatabaseLengthUnits
		oMS.Activate
		Dim oCOC_X As Double = UOM.ConvertUnits(oCOG.X, oDBLengthUnits, oDocLengthUnits)
		Dim oCOC_Y As Double = UOM.ConvertUnits(oCOG.Y, oDBLengthUnits, oDocLengthUnits)
		Dim oCOC_Z As Double = UOM.ConvertUnits(oCOG.Z, oDBLengthUnits, oDocLengthUnits)
		Ixx = UOM.ConvertUnits(Ixx, oDBLengthUnits, oDocLengthUnits)
		Iyy = UOM.ConvertUnits(Iyy, oDBLengthUnits, oDocLengthUnits)
		Izz = UOM.ConvertUnits(Izz, oDBLengthUnits, oDocLengthUnits)
		TryCreateUpdateCustomProperty(oMSDoc, oMS.Name & "_COG X coordinate", oCOC_X)
		TryCreateUpdateCustomProperty(oMSDoc, oMS.Name & "_COG Y coordinate", oCOC_Y)
		TryCreateUpdateCustomProperty(oMSDoc, oMS.Name & "_COG Z coordinate", oCOC_Z)
	Next 'oMS
	oOrigMS.Activate
End Sub
	Try
	Catch
	End Try
	Else
End Sub
Wesley Crihfield
rafael.barata
This saved and will save me a lot of work. Many thanks.
m_h_hashempour1999
Observer
Observer
Hi
can you help me creating rule to get mass properties of all model1 ((raw mattrial)) of each part in an assembly and have Bom colum for them
