Get list of properties / methods from given object
omartin
omartin
For example, when searching the docs for a particular object you get a list of its properties and methods, or when intelli-sense kicks in you get the list of properties and methods.
How can I get similar results? I was guessing reflection would work but I keep getting null reference. I am guessing because all the objects are automation interfaces??
Was my reply Helpful ? send a Kudos or accept as solution
You can only drive one mate at a time. what you need to look into is either animation in Inventor studio, or the presentation environment. Note that the presentation environment is usually used for assembly instructions, but with a bit of imagination, you can use it
Studio: https://www.youtube.com/watch?v=__EjxKIsy9E
Presentation: https://www.youtube.com/watch?v=fED0c-AioHk
JhoelForshav
Hi @omartin
Are you looking for a way to print out a list of all Properties/Methods in an Object with iLogic?
Try this rule as an example of how to do this:
Sub Main
	Dim oDoc = ThisDoc.Document
	GetObjectInfo(oDoc)
End Sub
Sub GetObjectInfo(ByRef oObj As Object)
Dim oPropsString As String = "Properties:"
Dim oMethodsString As String = "Methods:"
Dim oProps As System.Reflection.PropertyInfo() = oObj.GetType.GetProperties
Dim oMethods As System.Reflection.MethodInfo() = oObj.GetType.GetMethods
For Each oProp As System.Reflection.PropertyInfo In oProps
	oPropsString = oPropsString & vbCrLf & oProp.Name
Next
For Each oMethod As System.Reflection.MethodInfo In oMethods
	oMethodsString = oMethodsString & vbCrLf & oMethod.Name
Next
MsgBox(oPropsString)
MsgBox(oMethodsString)
End Sub
In this example I write out the properties and methods for the Document in whih the rule is ran, but you could use the sub for any object 🙂
robertast
@JhoelForshav
Well, you never cease to amaze. First this:
https://knowledge.autodesk.com/support/inventor/learn-explore/caas/simplecontent/content/ilogic-tool...
Now this. 🙂 (need to add a separator to the message - the whole message will not fit on the screen)
Already half of the "macro recording" and created 🙂
omartin
	Dim oDoc As DrawingDocument = ThisDoc.Document
	Dim dl As DrawingViewLabel
	Dim ds As Sheet
	ds = oDoc.Sheets(1)
	dl = ds.DrawingViews(1).Label
	GetObjectInfo(dl)
Hey@JhoelForshav thx for the RE:. You have the idea down, eventually I want to be able to run one the commands from the list.
I was working in visual studio but good to know ilogic as well.  I used the above to try and pass a drawing view label but i get no properties and looks like a generic list for the methods
JhoelForshav
Hi @omartin
You're right... GetType returns System.__ComObject for DrawingViewLabel 😞
I found another way to get the Properties though:
Dim oProps As System.ComponentModel.PropertyDescriptorCollection = System.ComponentModel.TypeDescriptor.GetProperties(oObj)
For Each oProp As System.ComponentModel.PropertyDescriptor In oProps
Next
End Sub
But no success on the methods so far.
omartin
Thx @JhoelForshav  😁 i never would have looked in here: System.ComponentModel.PropertyDescriptorCollection.
howd you find it hahah that should be good enough seems like most of the commands i was looking for are properties
