Get Item from ObjectsEnumerator C#
Hello.
I am using C# API.
I want to get intersection point from 2 curves.
SketchArc arc1 = ...(definition)
SketchLine chkLine1 = ...(definition)
LineSegment2d oLineSegment1 = chkLine1.Geometry;
ObjectsEnumerator objsEnum = oLineSegment1.IntersectWithCurve(arc1.Geometry);
int num1 = objsEnum.Count
After executing, I can see 1 line and 1 arc in Inventor.
If I check num1 in debug mode it shows 1 (intersection exists)
But cannot get point information.
From another posting there are some examples in VB like this
Set oInterPoint = oLineSegment.IntersectWithCurve(oSketchCircle.Geometry).Item(1)
oInterPoint.x = ...
This is VB so there is ObjectsEnumerator.Item() method.
In C# I cannot find method for Item[], or GetItem(), ...
If I can get intersection point coordinates it's OK however...
JelteDeJong
did you try:
oLineSegment.IntersectWithCurve(oSketchCircle.Geometry)[1]
Jelte de Jong
Blog: hjalte.nl - github.com
OK. It works. Thanks.
I need one more question for intersection. CurveCurveIntersection
below code is not working now in C#.
Would you give me solution?
SketchSpline sp1 = App2DSpline(aryPnt1, oSketch1);
SketchSpline sp2 = App2DSpline(aryPnt2, oSketch1);
BSplineCurve2d spDef1 = sp1.Geometry;
BSplineCurve2d spDef2 = sp2.Geometry;
Point2d intPt = (Point2d)oTransGeom.CurveCurveIntersection(spDef1, spDef2)[1];
double xx1 = intPt.X;
double yy1 = intPt.Y;
I found solution.
Below code works.
Thank you.
BSplineCurve spDef1 = sp1.Geometry3d;
BSplineCurve spDef2 = sp2.Geometry3d;
Inventor.Point intPt =oTransGeom.CurveCurveIntersection(spDef1, spDef2)[1];
