Get Idw or Dwg Title Block "Description" property
isocam
Message 1 of 11
isocam
Can anybody help?
I am trying to get an "idw" or "dwg" title blocks "DESCRIPTION" property using an Inventor macro.
For example, if the description property on a part (ipt) file is "SIDE PLATE", how can I can the same result if the file extension is a "idw" or a "dwg"?
Many thanks in advance!!!!
IsoCAM
Replies (10)
Message 2 of 11
Mike.Wohletz
I am guessing that this is an attributed AutoCAD tilte block and not a std Inventor title block? If so let me know as one will be a property and the other you are asking how to read the attributes.
Message 3 of 11
Explain bit more.. Examples or Screen Shot will be good.
Sounds it can be solved..
Message 4 of 11
Mike.Wohletz
If you are trying to get this from an attributed block the below should do what you want from inside a managed application. You will need to add the appropriate AutoCAD references to your solution and the proper import statements but I am using something like this everyday to get and set attributed block data. Let me know if you need anything on what references are needed if this is what you are trying to do.
    Public Function GetAcadBlockAttribute(ByVal BlockName As String, ByVal TagName As String) As String
        Dim acadDoc As AcadDatabase = m_inventorApplication.ActiveEditDocument
        For Each Ent As Object In acadDoc.PaperSpace
            If TypeOf Ent Is AcadBlockReference Then
                Dim bRef As AcadBlockReference = Ent
                If bRef.Name.ToUpper = BlockName.ToUpper Then
                    Dim myAtts As Object = Ent.GetAttributes
                    For i = LBound(myAtts) To UBound(myAtts)
                        If myAtts(i).TagString.ToString.ToUpper = TagName.ToUpper Then
                            Return myAtts(i).TextString
                    Next
        Next
        Return Nothing
    End Function
Message 5 of 11
isocam
I am creating either an "IDW" or "DWG" file from an Inventor "IPT" File.
I can get the description property for the "IPT" file, using VBA, but I need to get the description property for an "IDW" or "DWG" file that I have open in AutoDesk Inventor (NOT AUTOCAD)
Please see the attached screen dump from Inventor.
I need to extract the description property using VBA. In the case of the screen dump, this would be...
LASER CUT PROFILE - DIE DRIVE END PLATE
Many thanks!!!!
Message 6 of 11
Mike.Wohletz
You would get it just the same as you do from the part.
Sample:
    Public Sub DescriptionProperty()
        Dim DescriptionValue As String = GetProperty(m_InventorApplication.ActiveDocument, "Description")
        'do what you want with this property
    End Sub
    Public Function GetProperty(ByVal oDoc As Inventor.Document, ByVal PropertyName As String) As String
        Try
            Dim oDTP As PropertySet = oDoc.PropertySets.Item("Design Tracking Properties")
            GetProperty = oDTP.Item(PropertyName).Value
        Catch ex As Exception
            Return ""
        End Try
        Return GetProperty
    End Function
The code I posted before is also for Inventor and not AutoCAD but is for reading attributed AutoCAD blocks in an Inventor drawing. It is all in .NET and not VBA so you will need to do some converting if this is for VBA.
Message 7 of 11
isocam
Hi
This is the Sub I have on Test
Sub GetTitleBlockDescriptionProperty()
    Dim Doc As Document
    Set Doc = ThisApplication.ActiveDocument
    Dim invDescriptionProperty As Property
    Set invDescriptionProperty = Doc.PropertySets.Item("Design Tracking Properties").Item("Description")
    Description = UCase$(invDescriptionProperty.Value)
    Stop
End Sub
I have an Idw file open in inventor. I cannot get the VBA macro to give me the description that is in the title block
Can you tell me what I am doing wrong. It runs, but does not give the property "Description"
Many Thanks!!!
Message 8 of 11
This is a snippet that I use to get my drawing's referenced document's description. Sounds like that is maybe what you are trying to do.
Dim oDoc As Document
If oDoc.DocumentType = kDrawingDocumentObject Then
Dim m_PartDoc As Document
For Each m_PartDoc In oDoc.ReferencedDocuments
sPartDescriptionValue = m_PartDoc.PropertySets.Item("Design Tracking Properties").Item("Description").Value
Next
Message 9 of 11
Mike.Wohletz
I just ran the below in a drawing and it returns the description value from the iProperties. is your title block populated from the iProperty "Description"?
    Dim Doc As Document
 Dim Description As String
   MsgBox (Description)
    Stop
End Sub
Message 10 of 11
Yes, that's right. All of our title block fields are linked to the referenced part's iProperties.
Message 11 of 11
xiaodong_liang
Autodesk Support
Autodesk Support
So, you will need to get the document of referenced part, and read its iProperties. just add some more lines, e.g.
    Dim Doc As Document
Dim oPartDoc as PartDocument
Set oPartDoc = Doc.ReferencedDocumentDescriptors(1).ReferencedDocument Dim invDescriptionProperty As Property Set invDescriptionProperty = oPartDoc.PropertySets.Item("Design Tracking Properties").Item("Description") Dim Description As String Description = UCase$(invDescriptionProperty.Value) MsgBox (Description) Stop End Sub
