Get full filename of inserted model on the current sheet.
C_Haines_ENG
C_Haines_ENG
I am having a very hard time getting the full file name of the inserted model on the CURRENT SHEET. I have the code for the first model in the entire document.
oModelDoc = ThisDrawing.ModelDocument
modelName = IO.Path.GetFileName(oModelDoc.FullFileName)
 How do I change this to only select the first model inserted on the current sheet?
WCrihfield
There are several ways to get there, but here is one way:
oView = ActiveSheet.DrawingViews.NativeEntity.Item(1)
Dim oModelDoc As Document = oView.ReferencedDocumentDescriptor.ReferencedDocument
Wesley Crihfield
(Not an Autodesk Employee)
C_Haines_ENG
Helpful as always! as a Side note is there a way to tell if its a .iam or a .ipt with this code?
JelteDeJong
Not so much information on how you would like to add the file name on your sheet. but this iLogic rule will show you the file name of the model that belongs to the first view of sheet 3.
Dim doc As DrawingDocument = ThisDoc.Document
Dim sheet As Sheet = doc.Sheets.Item(3)
Dim view1 As DrawingView = sheet.DrawingViews.Item(1)
Dim fileName As String = view1.ReferencedFile.FullFileName
MsgBox(fileName)
Jelte de Jong
Blog: hjalte.nl - github.com
WCrihfield
Here is a quickie for checking the DocumentType of a view's model document:
oRDD = oView.ReferencedDocumentDescriptor
Dim oModelType As String
If oRDD.ReferencedDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
	oModelType = "Assembly"
ElseIf oRDD.ReferencedDocumentType = DocumentTypeEnum.kPartDocumentObject Then
	oModelType = "Part"
MsgBox("The type of Model on this sheet = " & oModelType,,"")
Wesley Crihfield
