Get first element of pattern
GeorgK
Advisor Advisor
GeorgK
Hello together,
I would like to select a hole and get the first element from an RectangularPattern or CircularPattern feature in part environment. How could I achieve this?
 Dim m_inventorApp As Inventor.Application = Nothing
        m_inventorApp = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application")
        ' Get the selected face.
        On Error Resume Next
        Dim oFace As Face
        oFace = m_inventorApp.ActiveDocument.SelectSet.Item(1)
        ' Check to see if this face was created by an extrude,
        ' revolve, or hole feature.
        Dim oCreatedByFeature As PartFeature
        oCreatedByFeature = oFace.CreatedByFeature
        ' Get the associated sketch.
        Dim oSketch As PlanarSketch
        If TypeOf oCreatedByFeature Is HoleFeature Then
            Dim oHole As HoleFeature
            oHole = oCreatedByFeature
            MsgBox(oHole.Name)
        ElseIf TypeOf oCreatedByFeature Is RectangularPatternFeature Or TypeOf oCreatedByFeature Is CircularPatternFeature Then
            oHole = oCreatedByFeature.ParentFeatures.Item(1)
            MsgBox(oHole.Name & " Circular or Rectangular Pattern")
Thank you
Georg
HermJan.Otterman
Hello Georg,
try this:
Dim oPartDoc As Inventor.PartDocument = m_inventorApplication.ActiveDocument
Dim selectedFace As Face = oPartDoc.SelectSet(1)
Dim InternalName As String = selectedFace.InternalName
Dim oFeatures As Inventor.PartFeatures = oPartDoc.ComponentDefinition.Features
Dim elementFound As Boolean = False
If oFeatures.RectangularPatternFeatures.Count > 0 Then
For Each oRectPat As RectangularPatternFeature In oFeatures.RectangularPatternFeatures
For Each oElement As FeaturePatternElement In oRectPat.PatternElements
For Each oFace As Face In oElement.Faces
If oFace.InternalName = InternalName Then
oPartDoc.SelectSet.Clear()
oPartDoc.SelectSet.Select(oRectPat.PatternElements(1))
elementFound = True
Exit For
Next
If elementFound = True Then Exit For
Next
Next
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
GeorgK
Hello Herm Jan,
thanks for the code. How could I change the hole diameter?
Georg
HermJan.Otterman
how do you make the part?
if you create a sketch of the hole, or make a hole feature, you get a parameter for the diameter.
give it a name and you can find it again.!?
ok, changed the code a bit:
Dim oPartDoc As Inventor.PartDocument = _inventorApplication.ActiveDocument
' change:
Dim oRectPat As RectangularPatternFeature = Nothing
' change:
For Each oRectPat In oFeatures.RectangularPatternFeatures
elementFound = True
Exit For
Next
Next
Next
'Add: if hole created with one extrude feature:
Dim oParentFeature As Object = oRectPat.ParentFeatures(1)
For Each oParam As Inventor.Parameter In oParentFeature.Parameters
MsgBox(oParam.Name)
MsgBox(oParam.Value)
Next
' you still have to know the name of the parameter..!!??
Herm Jan
GeorgK
Hello Herm Jan,
thanks for the code. I could solve it now.
Georg
