Get file extension and BOM Structured value from partlist row
quanguyvl
quanguyvl
Hello
I want to sort my partlist by group, with three groups consist: Assembly, part and standard part. I have an idea to sort it by get file extension and BOM Structured value on each row then renumber them. But, I don't know API to get that values over partlist row. Thanks for your help.
WCrihfield
Hi @quanguyvl.  Can you better explain what you mean by "part and standard part" (the last two out of three groupings)?  I have some code you can play with that will get document type and BOMStructure from the document in each row, but I still have no idea how you plan to use these, or how you plan to renumber the whole PartsList using only these pieces of data.  If you could explain your plans in more detail, and more specifically how you want everything to be ordered in the parts list, we might be able to help you out better, and maybe present better suited complete solutions.
Here is the iLogic rule code I have for you so far:
Sub Main
	If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then
		MsgBox("A Drawing Document must be active for this rule to work. Exiting.",vbCritical, "WRONG DOCUMENT TYPE")
		Exit Sub
	Dim oDDoc As DrawingDocument = ThisApplication.ActiveDocument
	Dim oPList As PartsList
	Try
		oPList = oDDoc.ActiveSheet.PartsLists.Item(1)
	Catch
		MsgBox("No PartsList found on Active Sheet.", , "")
	End Try
	If IsNothing(oPList) Then Exit Sub
	For Each oRow As PartsListRow In oPList.PartsListRows
		Dim oRowDoc As Document = GetPListRowDoc(oRow)
		If IsNothing(oRowDoc) Then Continue For
		Dim oDocType As DocumentTypeEnum = oRowDoc.DocumentType
		Dim oBOMStruct As BOMStructureEnum = oRowDoc.ComponentDefinition.BOMStructure
		MsgBox("oDocType = " & oDocType.ToString & vbCrLf & "oBOMStruct = " & oBOMStruct.ToString,,"")
	Next
End Sub
Function GetPListRowDoc(oPListRow As PartsListRow) As Document
	If oPListRow.ReferencedRows.Count = 0 Then Exit Function
	Dim oDBOMRow As DrawingBOMRow = oPListRow.ReferencedRows.Item(1)
	'If oDBOMRow.Virtual Then Exit Function
	Try
		oRowDoc = oDBOMRow.BOMRow.ComponentDefinitions.Item(1).Document
	Catch
	End Try
	If Not IsNothing(oRowDoc) Then Return oRowDoc
End Function
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you want and have time, I would appreciate your Vote(s) for My IDEAS 💡or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
quanguyvl
Thank for your help. I have found it. I mean Standart part is purchased item such as: nuts, bolts... here is my idea:
Public Sub modify_partlist()
' Make sure a drawing document is active.
Dim drawDoc As Document
On Error Resume Next
Set drawDoc = ThisApplication.ActiveDocument
If Not (TypeOf drawDoc Is DrawingDocument) Then
MsgBox "A drawing must be active."
'Make sure a parts list is selected.
Dim partList As Object
Set partList = drawDoc.SelectSet.Item(1)
If Not (TypeOf partList Is PartsList) Then
MsgBox "A parts list must be selected."
Dim STT As Integer
STT = 1
'Sort to Title
partList.Sort (partList.PartsListColumns(5).Title)
'Index assembly
For i = 1 To partList.PartsListRows.Count
 If partList.PartsListRows(i).ReferencedRows(1).BOMRow _
 .BOMStructure <> BOMStructureEnum.kPurchasedBOMStructure _
 And partList.PartsListRows(i).ReferencedRows(1).BOMRow.ComponentDefinitions(1) _
 .Document.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject _
 Then
  partList.PartsListRows(i).Item(3).Value = STT
  STT = STT + 1
Next i
'Index part
For j = 1 To partList.PartsListRows.Count
 If partList.PartsListRows(j).ReferencedRows(1).BOMRow _
 And partList.PartsListRows(j).ReferencedRows(1).BOMRow.ComponentDefinitions(1) _
 .Document.DocumentType = DocumentTypeEnum.kPartDocumentObject _
 Then
  partList.PartsListRows(j).Item(3).Value = STT
  STT = STT + 1
Next j
'Index standard part
For k = 1 To partList.PartsListRows.Count
 If partList.PartsListRows(k).ReferencedRows(1).BOMRow _
 .BOMStructure = BOMStructureEnum.kPurchasedBOMStructure _
 Then
  partList.PartsListRows(k).Item(3).Value = STT
  STT = STT + 1
Next k
'Sort to Item number
partList.Sort (partList.PartsListColumns(3).Title)
'Override to BOM
partList.SaveItemOverridesToBOM
End Sub
