Get BOM for a derived assembly or part
shastu
Advisor Advisor
shastu
Is there really no way to accomplish this?  If a part is derived, I want to be able to extract the information of what it was made from.  If I have an assembly abc that is made from parts 1, 2, and 3.  I can extract the BOM from abc.iam to an excel spreadsheet.  If however that same assembly is derived to file xyz.ipt, then I cannot extract the BOM.  I need to be able to extract the information that xyz is made from abc consisting of parts 1,2, and 3.  Does anyone know of a way to do that in VBA?  Any help would be greatly appreciated!!!
bshbsh
there are ways to do this.
if your part is a component is a derived from another part, then it will have a reference to that part in
.ComponentDefinition.ReferenceComponents.DerivedPartComponents
if your part is a component is a derived from an assembly, then it will have a reference to that assembly in
.ComponentDefinition.ReferenceComponents.DerivedAssemblyComponents
you have to check the .Count property on these and branch your code if any of that is non zero.
let's say, you have a DerivedAssemblyComponents.Count = 1, then you can access the ComponentDefinition of that original Assembly through:
DerivedAssemblyComponents.Item(1).ReferencedDocumentDescriptor.ReferencedDocument.ComponentDefinition
this will not work if the link to the referenced assembly (or part) is suppressed or entirely unlinked. make sure to check this too:
DerivedAssemblyComponents.Item(1).LinkedToFile
and
DerivedAssemblyComponents.Item(1).SuppressLinkToFile
