Get Body that was mirrored
Raider_71
Raider_71
Hi I am struggling to find a way to get the body or bodies collection of a Part Mirror feature. Basically, if a Surface Body of a multi-body part was mirrored, instead of mirroring a feature or features.
Please see sample parts attached for clarity.
I have tried to retrieve the information from the MirrorFeatureDefinition object but cant seem to find a property that exposes the collection of mirrored surface bodies. The ParentFeatures property is empty in this case because its a not a feature mirror.
Any idea?
    Function GetExtrudeFeatureFromMirror(oMirrorFeature As Inventor.MirrorFeature) As Inventor.SurfaceBody
        Dim oDef As MirrorFeatureDefinition
        oDef = oMirrorFeature.Definition
        For Each oFeat In oDef.ParentFeatures
        Next
        Return Nothing
    End Function
C_Haines_ENG
This will show you the name of the first surface body in the mirror feature.
Sub Main
	Dim oDoc As PartDocument = ThisDoc.Document
	Dim oMirror As MirrorFeature = oDoc.ComponentDefinition.Features.MirrorFeatures(1)
	MsgBox(oMirror.SurfaceBodies.Item(1).Name)
End Sub
Raider_71
Hi @C_Haines_ENG
Thanks for your reply. I did not think of that, but when I tried your solution, it returns the name "Solid2". I am trying to determine which solid was mirrored to create Solid2. i.e. I need the function to tell me "Solid1" because that was the body which was mirrored to create "Solid2".
I hope that makes sense?
C_Haines_ENG
Ah I see. I remember running into this issue a while back, and the solution sucks! This will do what you're looking for, but it requires the code to go through the entire browser tree to find the "Pattern of" nodes. I'm sure there's a way of optimizing this, but this is the most "error free" version.
Sub Main
	Dim oSolidBodyNode As BrowserNode = GetSolidBodyNode
	For Each oSolidNode As BrowserNode In oSolidBodyNode.BrowserNodes
		Dim oPatternNode As String = CheckForPattern(oSolidNode)
		If oPatternNode IsNot Nothing Then MsgBox( _
			"Patterened Solid : " & oPatternNode & vbLf & "Created Solid : " & oSolidNode.BrowserNodeDefinition.Label & vbLf)
	Next
End Sub
Function GetSolidBodyNode
	For Each oNode_1 As BrowserNode In ThisDoc.Document.BrowserPanes.Item("Model").TopNode.BrowserNodes
		If oNode_1.BrowserNodeDefinition.Label.Contains("Solid Bodies") Then Return oNode_1
	Next
End Function
Function CheckForPattern(oNode As BrowserNode)
	For Each oSubSolidNode As BrowserNode In oNode.BrowserNodes
		If oSubSolidNode.BrowserNodeDefinition.Label.Contains("Pattern of ")
			Return Replace(Split(oSubSolidNode.BrowserNodeDefinition.Label, ":")(0), "Pattern of ", "")
	Next
	Return Nothing
End Function
Raider_71
Hi @C_Haines_ENG, thanks for the workaround. It's crazy that we have to do it this way... @Autodesk PLEASE sort this out and add a method / property for us to get the source solid body(s) of a pattern.
Just an FYI, what I have done is build a dictionary upfront by traversing the browser tree once. Because I have to get references many times its much faster this way compared to having to traverse the browser tree for each check.
Cheers and thanks again for your help!
