Get appearance at part level from Assembly
SharkDesign
Mentor Mentor
SharkDesign
I'm using this to go through all occurences
Sub Main
Dim oDoc As AssemblyDocument = ThisApplication.ActiveDocument
	Dim oCompDef As AssemblyComponentDefinition = oDoc.ComponentDefinition
	Dim oOcc_s As ComponentOccurrences = oCompDef.Occurrences
	'look at each occurrence in the assembly
	For Each oOcc As ComponentOccurrence In oOcc_s
		ListOccurences(oOcc)
	Next
End Sub
Sub ListOccurences(oOcc)
	If Not oOcc.Name.Contains("Weldbead")
		Try 'Prevents Weldment and simulation file errors
			'Do stuff Here!
		For Each subOcc As ComponentOccurrence In oOcc.SubOccurrences
			ListOccurences(subOcc)
		Next
		Catch'Weldment
		End Try
End Sub
In the do stuff here, I want to get the appearance of the occurrence at part level.  i.e. "anodise"
I've tried the following:
Component.Color("part1:2")
 And also
iProperties.PartColor("part1:2")
But they all just bring back 'As Material' which I assume is actually getting the appearance at assembly level (unless there's an override.)
I feel like it should be pretty simple, but everything I've found about appearances online for other tasks are lines and lines of code.
  Inventor Certified Professional
JhoelForshav
Hi @SharkDesign
Are you trying to get the active appearance of the actual part document and not the occurrence in assembly environment? See example below:
'Get an occurrence
Dim oOcc As ComponentOccurrence = ThisDoc.Document.ComponentDefinition.Occurrences(1)
'Get the part document of occurrence
Dim oDoc As Document = oOcc.Definition.Document
'Get the active appearance and display its name in messagebox
MsgBox(oDoc.ActiveAppearance.DisplayName)
SharkDesign
I'm wanting the actual appearance contained in the part, not an overridden value.
Using the same code for looping above, I use this line and it gets the material perfectly, but was trying to do the same for appearance.
oMatPick = iProperties.MaterialOfComponent(oOcc.Name)
I'm basically doing, if that appearance matches (anodised for instance) write iproperty.
Just couldn't work out how to get it to read the actual appearance.
nmunro
You need to examine the active appearance at the part level. A short vba macro below should help.
Public Sub GetAppearance()
    Dim doc As AssemblyDocument
    Set doc = ThisDocument
    Dim occurs As ComponentOccurrences
    Set occurs = doc.ComponentDefinition.Occurrences
    Dim occur As ComponentOccurrence
    Dim partDoc As PartDocument
    For Each occur In occurs
        If occur.DefinitionDocumentType = kPartDocumentObject Then
            Set partDoc = occur.Definition.Document
            MsgBox occur.Name & " - " & partDoc.ActiveAppearance.DisplayName
    Next occur
End Sub
https://c3mcad.com
SharkDesign
Thanks, I don't use VBA, but I was able to use your code.
The bit I needed was this, which I slightly modified.
partDoc = oOcc.Definition.Document
mystring = partDoc.ActiveAppearance.DisplayName
