Get all EdgeProxies of a given Edge
Ralf_Krieg
Advisor Advisor
Ralf_Krieg
Hello
I have an assembly containing subassemblies and parts. If i have an part edge, is there a way to get all edgeproxies representing this edge in context of the main assembly? I can circle through all edgeproxies in the assembly context and check if the native object is my edge, but this is very slow.
R. Krieg
RKW Solutions
www.rkw-solutions.com
JhoelForshav
Hi @Ralf_Krieg
Something like this maybe? 🙂
Sub Main
'Get a nativeobject for an edge, I dont know where you're getting the edge object from.
Dim oEdge As Edge = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartEdgeFilter, "Pick edge.").NativeObject
Dim oPart As PartDocument = oEdge.Parent.ComponentDefinition.Document
Dim oAsm As AssemblyDocument = ThisDoc.Document
Dim oSelSet As SelectSet = oAsm.SelectSet
Dim oEdgeCol As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
For Each oOcc As ComponentOccurrence In oAsm.ComponentDefinition.Occurrences.AllReferencedOccurrences(oPart)
	Dim oEdgeProx As EdgeProxy = CreateEdgeProxy(oOcc.OccurrencePath, oEdge)
	oEdgeCol.Add(oEdgeProx)
Next
oSelSet.SelectMultiple(oEdgeCol)
End Sub
Function CreateEdgeProxy(oOccList As ComponentOccurrencesEnumerator, oEdge As Edge) As Object
	Dim oProx As Object
	For i = oOccList.Count To 1 Step -1
		If i = oOccList.Count
			Call oOccList(i).CreateGeometryProxy(oEdge, oProx)
		Else
			Call oOccList(i).CreateGeometryProxy(oProx, oProx)
	Next
	Return oProx
End Function
JhoelForshav
I just realized you don't have to send the proxy up through each occurrence of the occurrencepath.
This will do.
'Get a nativeobject for an edge.
'Get the part document the edge belongs to.
'Get the top level assembly
'Get the Assemblys select set.
'Create an ObjectCollection to add all edge proxies to.
'Loop through all occurrences of the part.
	'Create a proxy for the edge
	oOcc.CreateGeometryProxy(oEdge, oEdgeProx)
	'Add proxy to the object collection
Next
'Select everything in the object collection
Ralf_Krieg
Hello
Thank you. I have integrated your second code. Works perfect. 👍
R. Krieg
RKW Solutions
sam
Thanks for this one - took me a while to figure out edgeproxy (:$)
