General Tools in IV2013
Message 1 of 25
Hi to all,
just instaled Inventor Suit 2013,
after installation I run UserTools.msi
from GeneralTools/Bin folder registerd GeneralTolls.dll.
AddIns GeneralTools is loaded
In Add-In tab is not GeneralTool commands (spell, helix).
How to force Inventor to to show this tool
Please Help
uu
My system:
Dell w/ E5405@2 MHz + 14 GB
Windiws XP-64
Replies (24)
Message 21 of 25
YuhanZhang
Hi Danijel,
Have you any other machine there to validate if the issue reproducible? Which OS do you use?
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
Message 22 of 25
danijel.radenkovic
Hello Rocky,
I have tried on the other machine and I am getting the same error. Both of the machines have the same versions of frameworks and the same operating system installed. Windows 8.
Regards
Danijel
Inventor 2018/Windows 10 x64
If this information was helpful, please consider marking it as an Accepted Solution by using the Accept as Solution. Kudos are also gladly accepted.
Message 23 of 25
YuhanZhang
Hi Danijel,
I configured a Windows 8.1 machine with Inventor 2016, and just ran the Install.bat then the addin works well, the machine has not any VS installed yet. Is your current user the administrator user? Can you copy the folder C:\Users\Public\Documents\Autodesk\Inventor 2016\SDK\UserTools\DerivedPart_SP\ to a different folder like D:\Temp\ and run the Install.bat to see if it works?
Below is the snapshot of the addin control in the panel in Windows 8:
Rocky Zhang
Inventor API PD
Autodesk, Inc.
Message 24 of 25
danijel.radenkovic
Hello Rocky,
I tried with copying to another path and running install.bat, also with running through the cmd (run as administrator) on the new path and still the same error. I have installed Windows 8, not 8.1. Thank you very much for the any help that you provided. I will move on Windows 10 soon, so I hope it will works.
Regards
Danijel
Message 25 of 25
danijel.radenkovic
Hello Rocky,
I just want to inform you that I have moved to Windows 10 x64 and followed again by your steps I have registered UserTools and now it works fine.
Thank you very much on your engagement to help me to solve a problem. All your instructions were correct but I had a problem with my earlier operating system.
Best regards
Danijel
