改进!
改进!
DWJ丶
改进!
DWJ丶
1. It is strongly recommended to increase the rotation settings of the middle keys of the mouse (in most cases, we need to observe the design, but translation is relatively not so high in usage. It can be set as follows: every time the middle keys are pressed to rotate in the center of the element, no additional clicks are needed, and every time F4 clicks to determine the rotation center is a headache and too troublesome). The sketch cancels the F7 command, the direct sketch top-level display (each time pressing F7 is very troublesome) 3, rectangular array, can not directly select components, you need to open components or browser level to select 4, parts if you can, cancel the selection elements, unify parts, parts, surface lines, feature selection (you do not think it is necessary every time) Is it difficult to choose the right person? 5. Enhance the mirror command, no restrictions after the mirror! And we need to change the mirror center surface, mirror linkage 6, increase with the replication command. Sometimes it's very convenient to replicate non-arrayable parts (although it's a bit silly, but still can improve efficiency). 7. We usually modify the size of parts in place in the component environment, and need to add similar SolidWorks Inst urgently. Ant 3D in the ruler command, point features can display sketches and feature sizes so that it will be very convenient to modify the size, each step of clicking the mouse to display sketches or edit features will be very troublesome (and you need to click the mouse to modify the size) 8, sketches are best to add midpoint coordination constraints, each choice of overlap constraints mouse on. In Figure 9, the sketch size can be dragged up and down every time the mouse is placed on the size value. This is very troublesome. We need the mouse to be able to drag up and down on the size line (and the mouse drag state is not very sensitive in the 2020 version). It is better to increase the automatic magnetism between multiple sizes. Adsorption smoothness, because it is too troublesome to draw a standard 10,3-D sketch completely. I don't explain 11. The endpoint of each drag line in the sketch can't stretch the line (need to close the display to operate). We need to drag the endpoint in any state to pull the line, because it's convenient for 12, directly in the sketch. In the Component Environment Browser, the right mouse button adds renaming function to the part (and automatically modify the name of the engineering drawing after modifying the part so as to ensure association) 13. I hope that BOM can export excl custom template, but I may not find it! 14. In the project folder, there are usually many parts that are not used in the original design. We hope that the parts in use can not be deleted when the parts are opened (so that we can easily delete the unused parts uniformly, and the parts used indicate that they are not deleted). 15. Open the software every time. Whether the initial interface is cool or not (just like SolidWorks, sometimes it's important to force: smileytongue:) 16, add the command of direct weighing, every time you open the iProperty troublesome!!!17, strongly suggest clicking on the part can jump into the visual range of the part in the part browser, do not look in the browser again! 18. If possible, add the "Array and Mirror" command 19, add the color on the automatic batch random parts, and design a scheme list. Each scheme can be deleted 20, add the batch replacement template command 21. The BOM table needs to be assembled and exported with the parts, not separately. Maybe I will not operate! 22. Add the function of automatically adding graph numbers in batches according to the rules, (prefix suffix increases, and meets component suffix 0.00, in component suffix). It will be very convenient to find the part according to the figure number, so that according to the drawing workshop installation 23, automatic batch deletion increases the same part custom attribute 25, clicking on the browser part in the component environment can modify the part attributes (inventor graphics performance is so powerful). Why not add the function of operation in component environment, because it's simple, simple and fast. 26. Adding chain array 27 requires project replication mobile folder operation 28. All pop-up windows follow the mouse cursor position (for example, the corner toolbar mouse doesn't need to move far "although it can be fixed", so it can be done. With quick click operation) 29, the structure seems to be very troublesome to operate. There are too many levels of components and uniform pruning is a little tiring. It can be similar to SolidWorks group to solve this problem (I know there may be intellectual property protection, but we can think about it together). 30. There is no way to choose two sides for one part in the component environment. Create an intermediate working face! I hope it can be changed! 31. Each time hidden parts or transparent total pop-up dialog box "Design Visibility" and "Delete Relevance" need default options, no pop-up 32, add custom keyboard commands, which can be Ctrl / shift + mouse click union (mouse three keys are optional), such as from other software (sw, ug, catia, proe) Coming engineers can set up their previous software operation habits and hope that inventors can set up more inclusive operation. Do you think this will attract more customers? 33. Modify keyboard custom keyboard shortcut prompt repeat the current version did not see the prompt summary: Inventor's advantages: very friendly with AutoCAD, graphics performance is extremely fluent, including engineering drawings, sketches and other commands similar to AutoCAD, hope that inventor program development engineers, with the mouse keyboard operation times less for the software to open. The development principle, because it will be very convenient for us to design, engineers in China have a very precious time, often need a relatively short time to get market recognition, of course, engineers all over the world have the same time.
设计之上!
CCarreiras
Hi!
This is a user's forum, it's a waste of time to complain here, we use the software, we don't build it.
Place here your ideas.
https://forums.autodesk.com/t5/inventor-ideas/idb-p/v1232
Also, Sign as a beta tester and help developers to create better software.
CCarreiras
