Function not returning a value
daltonNYAW9
daltonNYAW9
I'm trying a make an ilogic rule that converts our vault file structure to our company's file structure.
The issue I'm having is the function creates the correct string value, but when I try to return it shows up blank.
Rule below. Highlighted the areas giving me trouble.
Sub Main
	Dim filepath As String = ThisDoc.Path
	filepath = "C:\_Vault\Designs\Customers\Koppers\Galesburg, IL\22-7008M Sorter Upgrade Equipment\29-Upper Drag Chain\01-Catwalk\22-321127.ipt"
	filepath = filepath.Replace("C:\_IPI_Vault\Designs", "T:")
	Dim index As Integer
'	Dim folderpath As String
'	If filepath.Contains("A Level 2 customers")
'		index = GetNthIndex(filepath & "\", "\", 6)
'		folderpath = CreateFolderPath(filepath.Split("\"), Left(filepath, index), 6)
'	Else
'		index = GetNthIndex(filepath & "\", "\",5)
'		folderpath1 = CreateFolderPath(filepath.Split("\"), Left(filepath, index), 5)
'		MessageBox.Show(folderpath1)
'	End If
	index = GetNthIndex(filepath & "\", "\", 5)
	folderpath = CreateFolderPath(filepath.Split("\"), Left(filepath, index), 5)
	MessageBox.Show(folderpath)
End Sub
Public Function GetNthIndex(searchString As String , charToFind As Char, n As Integer) As Integer
	Dim charIndexPair = searchString.Select(Function(c, i) New With {.Character = c, .Index = i }) _
	.Where(Function(x) x.Character = charToFind).ElementAtOrDefault(n - 1)
	Return If (charIndexPair IsNot Nothing, charIndexPair.Index, -1)
End Function
Public Function CreateFolderPath(folders As String(), folderpath As String, i As Integer)
'	MessageBox.Show(folderpath)
	If IO.Directory.Exists(folderpath & "\Sub Jobs\" & folders(i))
		CreateFolderPath(folders, folderpath & "\Sub Jobs\" & folders(i), i + 1)
	Else
		Return folderpath
End Function
FINET_Laurent
Hello @daltonNYAW9,
The function return object type is not specified :
Public Function CreateFolderPath(folders As String(), folderpath As String, i As Integer) as String
Kind regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
daltonNYAW9
Thanks for the quick reply! Yep it was a formatting error. I made the following changes in red.
Public Function CreateFolderPath(ByRef folders As String(), ByRef folderpath As String, ByRef i As Integer) As String
		folderpath = CreateFolderPath(folders, folderpath & "\Sub Jobs\" & folders(i), i + 1)
'		Exit Function
	Else
	Return folderpath
End Function
