Frame Generator
Frame Generator
Message 1 of 1
Frame Generator
               Please help me. I had this problem about Frame Generator. I had an Assembly, most of it are made from Frame Generator of the software then i tried to "check in" the Assembly in Vault. When I  "check out" the file for modification, the Assembly made from Frame Generator can't be edited. For example if i created L75x75x6 angle bar. I can't change the part into new one like L90x90x9. Is there a way that i could still use the Frame Generator in modifying its size?
Jac10
Replies (0)
