Frame Generator VBA Macro - Get Cut Lengths
isocam
isocam
Can anybody help?
I am trying to create a VBA macro that extracts all the "Cut Lengths" and  "Section Types" in a frame generated with "Frame Generator".
Attached in the macro that I have got so far.
(I have changed the filename from ".bas" to ".txt")
Does anybody know what I am doing wrong with the macro, as it does not work, or, has anybody got another macro that does the same thing?
Many thanks in advance!!!!
Darren
JhoelForshav
Hi @isocam
I made some edits to your code...
Try this:
Public Function GetCutLengths()
    Dim oDoc As Inventor.AssemblyDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oCompDef As Inventor.ComponentDefinition
    Set oCompDef = oDoc.ComponentDefinition
    Dim sMsg As String
    Dim iLeafNodes As Long
    Dim iFunctionAssemblies As Long
    Dim oCompOcc As ComponentOccurrence
    For Each oCompOcc In oCompDef.Occurrences
        If oCompOcc.DefinitionDocumentType = kPartDocumentObject Then
           iLeafNodes = iLeafNodes + 1
           Call Bounding_Box_Height(oCompOcc)
        Else
           iFunctionAssemblies = iFunctionAssemblies + 1
           Call ProcessAllFunctionOcc(oCompOcc, sMsg, iLeafNodes, iFunctionAssemblies)
    Next
    oDoc.Update
    oDoc.Save
End Function
Private Function ProcessAllFunctionOcc(ByVal oCompOcc As ComponentOccurrence, ByRef sMsg As String, ByRef iLeafNodes As Long, ByRef iFunctionAssemblies As Long)
    Dim oFunctionCompOcc As ComponentOccurrence
    For Each oFunctionCompOcc In oCompOcc.SubOccurrences
        If oFunctionCompOcc.DefinitionDocumentType = kPartDocumentObject Then
            Call Bounding_Box_Height(oFunctionCompOcc)
        Else
            sMsg = sMsg + oFunctionCompOcc.Name + vbCr
            Call ProcessAllFunctionOcc(oFunctionCompOcc, sMsg, iLeafNodes, iFunctionAssemblies)
    Next
End Function
Private Function Bounding_Box_Height(ByRef oCompOcc As ComponentOccurrence)
    Dim oDoc As Object
    Dim oparams As Parameters
    Dim oparam As Parameter
    Set oDoc = oCompOcc.Definition.Document
    Set oparams = oDoc.ComponentDefinition.Parameters
    If (TypeOf oDoc Is PartDocument) And (oDoc.IsModifiable) And (oDoc.DocumentInterests.HasInterest("{AC211AE0-A7A5-4589-916D-81C529DA6D17}")) Then
       Dim maxz As Double
       Dim minz As Double
       Dim height As Double
       maxz = oCompOcc.Definition.RangeBox.MaxPoint.Z
       minz = oCompOcc.Definition.RangeBox.MinPoint.Z
       height = maxz - minz
       For Each oparam In oparams.UserParameters
           If oparam.Name = "G_L" Then oparam.Value = height
       Next oparam
End Function
JhoelForshav
Looking at your code and your description of what you want to accomplish though, I think this would do what you want...
Sub GetLengths()
Dim oAsm As AssemblyDocument
Set oAsm = ThisApplication.ActiveDocument
Dim Msg As String
Dim oOcc As ComponentOccurrence
Dim oUM As UnitsOfMeasure
Set oUM = oAsm.UnitsOfMeasure
For Each oOcc In oAsm.ComponentDefinition.Occurrences.AllLeafOccurrences
    Dim oDoc As Document
    Set oDoc = oOcc.Definition.Document
    If (TypeOf oDoc Is PartDocument) _
        And (oDoc.IsModifiable) _
        And (oDoc.DocumentInterests.HasInterest _
     Dim maxz As Double
       Dim minz As Double
       maxz = oOcc.Definition.RangeBox.MaxPoint.Z
       minz = oOcc.Definition.RangeBox.MinPoint.Z
       On Error Resume Next
       If height <> 0 Then
        oDoc.ComponentDefinition.Parameters.UserParameters.Item("G_L").Value = height
        Msg = Msg & oOcc.Name & " - " & oUM.GetStringFromValue(height, oUM.LengthUnits) _
        & " - " & oDoc.PropertySets.Item("Design Tracking Properties").Item("Size Designation").Value & vbCrLf
Next
oAsm.Update
MsgBox Msg
End Sub
isocam
Jhoel,
Can I please ask if it is possible to also get the "Family" name using the VBA macro that you posted, below?
Please see the attached picture.
Darren
JhoelForshav
@isocam
Try this:
Sub GetLengths()
Dim Msg As String
     Dim maxz As Double
       Dim minz As Double
       If height <> 0 Then
        & " - " & oDoc.PropertySets.Item("Design Tracking Properties").Item("Size Designation").Value & _
         "- Family: " & oDoc.PropertySets.Item("Content Library Component Properties").Item("Family").Value & vbCrLf
Next
oAsm.Update
MsgBox Msg
End Sub
