Frame Generator IF end treatment exists
mtresky
mtresky
I'm looking to create a rule that searches frame members and determines if the have been modified (miter, notch, etc.) so I can extract that member info and use it for something.
If a member has just been cut to a length and is not modified in any other way, it is straight cut of stock. When we miter, notch, modify that part in any way it is no longer just a stock cut and I need to extract that information for company purposes.
I have already created a rule to cycle thru everything in the document, extract the individual names, file names, paths, etc. however I cannot find a way to flag end treatments. they are not treated as "features" that can be tested to be active as I thought.
I also tried using code to create the "CUTDETAIL1" custom iproperty in the parts (which is populated "out of the box" by frame gen when a treatment is applied) with no luck extracting that data either via code.
Any assistance would be great and appreciated, in either calling the end treatments directly or extracting the custom iProperty data for cuts. I have triple checked and the custom iProperty (CUTDETAIL1) for the member DOES exist and holds data (Value = "Miter 45.00 deg") , however my code is not pulling it for some reason.  is value is just blank in my message box everytime, where it is populated everytime i check it manually.
My code is below for reference:
Sub Main()
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
Call Iterate(oAsmDoc.ComponentDefinition.Occurrences, 1)
End Sub
Public Declare Sub Sleep Lib "kernel32"(ByVal dwMilliseconds As Long)
Private Sub Iterate(Occurrences As ComponentOccurrences, Level As Integer)
	'Iterate through Assembly
	Dim oOcc As ComponentOccurrence
	For Each oOcc In Occurrences
		'Find Parts in Assembly
		Dim oNAME As String = oOcc.Name
		Dim oPN As String = iProperties.Value(oNAME, "Project", "Part Number")
		Dim oFILE As Document = oOcc.Definition.Document
		Dim oFNAME As String = oFILE.FullFileName
		'find the postion Of the last backslash In the Path
		FNamePos = InStrRev(oFNAME, "\", -1)
		'get the file name with the file extension
		Name = Right(oFNAME, Len(oFNAME) -FNamePos)
		'get the file name (without extension)
		ShortName = Left(Name, Len(Name) -4)
		'get the path of the folder containing the file
		Folder_Location = Left(oFNAME, Len(oFNAME) -Len(Name))
		Dim CUT1 As String
		Try
			CUT1 = iProperties.Value(oFILE, "Custom", "CUTDETAIL1")
		Catch
			customPropertySet = oFILE.PropertySets.Item("Inventor User Defined Properties")
			customPropertySet.Add("", "CUTDETAIL1")
			CUT1 = iProperties.Value(oNAME, "Custom", "CUTDETAIL1")
		End Try
		MsgBox("LEVEL: " & Level _
		& vbLf & "DISPLAY: " & oNAME _
		& vbLf & "PN: " & oPN _
		& vbLf & "FULL PATH: " & oFNAME _
		& vbLf & "FILE NAME: " & Name _
		& vbLf & "PART NAME: " & ShortName _
		& vbLf & "FOLDER: " & Folder_Location _
		& vbLf & "CUT: " & CUT1)
		' Check to see if this occurrence represents a subassembly
		' and recursively call this function to traverse through it.
		If oOcc.DefinitionDocumentType = kAssemblyDocumentObject Then
			Call Iterate(oOcc.SubOccurrences, Level + 1)
	Next
End Sub
dalton98
I got it to show the custom iproperties value by using ".Expression" instead of ".Value". I've attached the code that i used.
'Dim oOcc As ComponentOccurrence
Dim oRefDoc As PartDocument
'oRefDoc = oOcc.ReferencedDocumentDescriptor.ReferencedDocument
oRefDoc = ThisApplication.ActiveDocument
Dim oProp As Inventor.Property
For Each oProp In oRefDoc.PropertySets.Item(4)
If oProp.Expression = "Notch"
	MessageBox.Show("notch")
ElseIf Left(oProp.Expression, 3) = "Cut"
	MessageBox.Show("cut")
Next
