Frame Generator customisation
Hey guys,
I use frame generator a heap for work. We use a standard size RHS of 75x50x5. The largest my inventor library goes to since updating to 2017 is 75x50x4. Using the AS 350g standard.
Any tips on how to update this so I have more sizes? I can find a couple vague guides but nothing step by step.
Brad
rhasell
Hi
I have the "Onesteel" Library.
Hopefully the file will attach.
See below.
Reg
2026.1
rhasell
Copy the file to your Content center folder.
Edit it via the Project editor, and the Content Center editor.
Reg
2026.1
rhasell
Hi
Just in case you weren't sure of the library, I made the assumption that you are from Aus, based on your user name.
The Onesteel library has been made up specifically by one of the VAR's for the Australian environment and contains all the Structural profiles.
Reg
2026.1
