frame generator custom part: Inventor 2018
pquenzi
pquenzi
I made a custom ipart and placed it in the frame generator in one of my Inventor projects. It worked fine as long as I was working in the project that I made the custom part in. However when I change projects, the part does not appear in the insert frame member dialog box. Is there some way I can get it to appear in all my projects or do I have to make the custom part over again for each project? Thank you. Phil Quenzi; pjquenzi@gmail.com
pquenzi
I'm good to go. I just needed to check the box for my custom library in the project folder. Phil.
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @pquenzi,
That's great!!! you found a solution
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
