formatted text in draft
breinkemeyer
breinkemeyer
I'm trying to build a string in C# for a hole callout(see attachment).  is there a way to access the insert symbol from the api, or, have a string combination to represent them?
theo.bot
In these cases I reverse engineer this, so first create the note manualy, then take the formatted text as result. Now you know how to build you own formatted string:
Sorry i use ilogic rules, no C#
oDoc.ActiveSheet.DrawingNotes.GeneralNotes.Item(1).FormattedText
result:
"Ø 5/8 THRU <Br/><StyleOverride Font='AIGDT'>v</StyleOverride> Ø 7/8 <StyleOverride Font='AIGDT'>x</StyleOverride> 7/16"
 Hope this helps to build your strings
breinkemeyer
Great idea, thanks!  I keep a little side project for things just like this.
