Format exposed custom property at Assembly level (iLogic)
CCarreiras
Mentor Mentor
CCarreiras
Hi!
I want to set  the parameter "Thickness" as exposed and also format the value from i.e. "5,000 mm" to "5 mm"
I want to do that on every part of the main assembly. (All parts are SheetMetal)
The first part is working(set as exposed), but formatting the property does not.
Any help?
SyntaxEditor Code Snippet
Dim openDoc As Document
openDoc = ThisApplication.ActiveDocument
Dim docFile As Document
If openDoc.DocumentType = 12291 Then
    For Each docFile In openDoc.AllReferencedDocuments
        If docFile.SubType.Equals("{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}") Then
        docFile.ComponentDefinition.Parameters("Thickness").ExposedAsProperty = True
	'___________NOT WORKING___________
 ShowUnitString = True
 ShowLeadingZeros = True
 ShowTrailingZeros = False
 Precision = kTwoDecimalPlacesPrecision
'_________________
Next
CCarreiras
rhasell
Hi
Give this a crack.
		oParam = docFile.ComponentDefinition.Parameters("Thickness")
		       'docFile.ComponentDefinition.Parameters("Thickness").ExposedAsProperty = True
			   oParam.ExposedAsProperty = True
			oFormat=oParam.CustomPropertyFormat 'For some reason or other this line is needed to enable the following formatting'
			oFormat.ShowUnitsString=True
			oFormat.ShowLeadingZeros=True
			oFormat.ShowTrailingZeros = False
			oFormat.Precision=Inventor.CustomPropertyPrecisionEnum.kOneDecimalPlacePrecision 'Set one decimal place
		Next
Regards
Reg
2026.1
CCarreiras
HI!
It works well.
Thank you very much.
CCarreiras
