For loop for changing the size of content center components
T3H
T3H
I need some help creating a for loop (or something similar) for changing the size of content center components.
I created the following code:
SyntaxEditor Code Snippet
If HardwareSize = .25 Then
Dim Circular_Washer_Inch = Components.AddContentCenterPart("Circular Washer (Inch) 1",
                                                           "Fasteners:Washers:Plain",
                                                           "Circular Washer (Inch)",
                                                           "1/4",
                                                           Circular_Washer_InchPos)
ElseIf HardwareSize = .3125 Then
                                                             "5/16",
 This successfully changes the size of a washer at position "Circular Washer (Inch) 1" based on a selected parameter "HardwareSize".
Now I want to change the size of washer 2, 3, 4 and so on.
Does anybody have a suggestion for how to do this?
Thanks.
T3H
I figured out a way (see below). I feel like there must be a much better way to do this though, if anybody has suggestions I'm all ears.
Dim I As Integer = 1
For I = 1 To 4
	Dim WasherName = "Circular Washer (Inch) " & I
	Dim NutName = "Hex Nut - Inch " & I
	Dim Circular_Washer_Inch = Components.AddContentCenterPart(WasherName,
                                                           "1/4",
    Dim Hex_Nut_Inch_1 = Components.AddContentCenterPart(NutName,
                                                         "Fasteners:Nuts:Hex",
                                                         "Hex Nut - Inch",
                                                         "1/4 - 20",
                                                         Hex_Nut_Inch_1Pos)
                                                             "5/16",
    Dim Hex_Nut_Inch_5_16_18 = Components.AddContentCenterPart(NutName,
                                                               "Hex Nut - Inch",
                                                               "5/16 - 18",
                                                               Hex_Nut_Inch_5_16_18Pos)
Next
chandra.shekar.g
Autodesk Support
Autodesk Support
@T3H,
If code is working, click on "Accept Solution".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
