For Each loop causes code to stop
shastu
Advisor Advisor
shastu
I have some code that is causing my code to stop until I move the mouse.  What is weird is if I run it enough times the problem goes away but if I then close Inventor and reopen the problem comes back.  It doesn't make any sense to me why moving my mouse would make it continue, but it does.  Is there anyway I can re-write this better to make the problem go away?  Thanks in advance.
Dim oApp As Inventor.Application
Set oApp = ThisApplication
Dim ODoc As DrawingDocument
Set ODoc = oApp.ActiveDocument
Dim oSheet As DrawingViews
Set oSheet = ODoc.ActiveSheet.DrawingViews
Dim sheetsB As Sheets
Set sheetsB = ODoc.Sheets
Dim sheetB As Sheet
For Each sheetB In sheetsB 'rotates through each sheet
sheetB.Activate
sheetB.update
Dim oDrgViews As DrawingViews
Set oDrgViews = sheetB.DrawingViews
Dim oDrgView As DrawingView
Debug.Print "loop_start" & Time
For Each oDrgView In oDrgViews
Number = Number + 1
If Number = 1 Then
ViewHeight = oDrgView.Height
viewWidth = oDrgView.Width
If Number = 2 Then
ViewLength = oDrgView.Width
If Number = 4 Then
ViewHeightIso = oDrgView.Height
ViewWidthIso = oDrgView.Width
Next
Next
Debug.Print "loop_end" & Time
JelteDeJong
You might want to have a look at this thread. With 2 possible solutions:
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/why-execution-is-faster-when-mouse-m...
Option 1:
Application.UserInterfaceManager.UserInteractionDisabled = true
 ' Your code here
Application.UserInterfaceManager.UserInteractionDisabled = false
Option 2:
Dim savedEnableBU = ThisApplication.DrawingOptions.EnableBackgroundUpdates
ThisApplication.DrawingOptions.EnableBackgroundUpdates = False
Try
   ' Your code here
Finally
  ThisApplication.DrawingOptions.EnableBackgroundUpdates = savedEnableBU
End Try
Jelte de Jong
Blog: hjalte.nl - github.com
shastu
I thought Option 1 worked the first time I tried it.  But now it doesn't again.  I am so confused.  it is the values that I am capturing that is causing it.  If I comment them out, then it isn't a problem.
shastu
Also if I create a msgbox before the first value is captured (oDrgView.Height) then it is fast as well.  Trying to think of any command that I could use to keep it going and not slow down.  If I actually wait long enough it will eventually continue.  There has to be a way to fix this.
