For each in sub assembly
jaimievandamme1
jaimievandamme1
Hello everyone,
I am unable to have all parts and sub-assembly as objects in an assembly.
see code. I always get a wood notification on the 2nd For Each.
can anyone help me?
'   Dim naam_project As String = InputBox("naam project", "geef de naam van het project", "")
Dim asmDoc As AssemblyDocument
asmDoc = ThisApplication.ActiveDocument
If asmDoc.DocumentType = kAssemblyDocumentObject Then
    Dim PTN_TRADEMARK As String
    naam_project = InputBox("naam project", "geef de naam van het project", "")
    Dim oFolderPath As String
    oFolderPath = ("C:\$WorkingFolder\PDF_AND_STEP\" & naam_project & "\")
    'MessageBox.Show("oFolderPath" & oFolderPath, "Title")
    Dim oVaultPath As String
    Dim oFileDownloadedSuccessfully As Boolean
    Dim oRuleArguments As Inventor.NameValueMap
    'Dim foutmeldingen As New ArrayList
     'Begin met de hoofdassemblage
    Dim asmDef As AssemblyComponentDefinition
    asmDef = asmDoc.ComponentDefinition
    Dim Occ As ComponentOccurrence
    For Each Occ In asmDef.Occurrences
        Dim subOcc As ComponentOccurrence
        For Each subOcc In Occ.SubOccurrences
            Dim subsubOcc As ComponentOccurrence
            For Each subsubOcc In subOcc.SubOccurrences
                Dim subsubsubOcc As ComponentOccurrence
                For Each subsubsubOcc In subsubOcc.SubOccurrences
                Next
             Next
        Next
    Next
    'MessageBox.Show(foutmeldingen, "Title")
Else
    MessageBox.Show("Het actieve document is geen samenstelling (assembly).", "error")
Frederick_Law
I use recursive loop to go through all sub-assemblies:
Sub SaveAsmThumbnail()
Dim oDoc As Inventor.Document
Dim oRefDoc As Inventor.Document
Dim oCompDoc As Inventor.Document
Set oDoc = ThisApplication.ActiveDocument
SaveThumbnail
For Each oRefDoc In oDoc.ReferencedDocuments
    If oRefDoc.IsModifiable Then
        Set oCompDoc = ThisApplication.Documents.Open(oRefDoc.FullFileName)
        SaveThumbnail
        If oCompDoc.ReferencedDocuments.Count > 0 Then
            Call procAllThumb(oRefDoc)
        oCompDoc.Close
Next
End Sub
Private Sub procAllThumb(ByVal oSubDoc As Inventor.Document)
    For Each oRefDoc In oSubDoc.ReferencedDocuments
        If oRefDoc.ReferencedDocuments.Count > 0 Then
'Do what you need here
        SaveThumbnail
        oCompDoc.Close
'Replace above code
    Next
End Sub
WCrihfield
Here is another example of a recursive Sub routine that can be used in an iLogic rule to iterate down through all levels of assembly components.  You just need to fill in some code for what you want to do with each component down within that custom Sub routine, where indicated.  I left a few lines in there, but commented out, just in case they may be useful to you.
Sub Main
	If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then Exit Sub
	Dim oADoc As AssemblyDocument = ThisDoc.Document
	Dim oOccs As ComponentOccurrences = oADoc.ComponentDefinition.Occurrences
	RecurseComponents(oOccs)
	If oADoc.RequiresUpdate Then oADoc.Update2(True)
	'If oADoc.Dirty Then oADoc.Save2(True)
End Sub
Sub RecurseComponents(oComps As ComponentOccurrences)
	If oComps Is Nothing OrElse oComps.Count = 0 Then Exit Sub
	For Each oComp As ComponentOccurrence In oComps
		If oComp.Suppressed Then Continue For 'if suppressed, you can not do much with it without error
		'If TypeOf oComp.Definition Is VirtualComponentDefinition Then Continue For 'virtual component
		'If TypeOf oComp.Definition Is WeldsComponentDefinition Then Continue For 'welds in Weldment type assembly
		'<<< add code here for doing something with this component >>>
		If oComp.Suppressed = False AndAlso _ 'can not access the Definition of a suppressed component
			oComp.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
			'use this next line when proxy connection to top assembly is not important
			RecurseComponents(oComp.Definition.Occurrences)
			'or (not also) use this next line instead to help maintain proxy connection to top assembly
			'RecurseComponents(oComp.SubOccurrences)
	Next
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
jaimievandamme1
tnx, its works. but i need to have acces to the assembly object where the part is in.
so oComps is a object whith multiple objects. but i need also the object of te assem where all te oComps are in.
Frederick_Law
'This oRefDoc could be assembly or derived
'Check file type
