Flipping "on" associate option on drawing views
NikelARH4K2
NikelARH4K2
I am trying to update a massive packet of drawing and view reps all need to be updated. Does anyone have a piece of code that will go through a drawing and flip on the "Associate" option and hit "OK" on every view on the current open idw?
It would save so much time for me rather than doing it manually
thank you
WCrihfield
Hi @NikelARH4K2.  Give this iLogic rule a try for that task.
Sub Main
	If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then Return
	Dim oDDoc As DrawingDocument = ThisDoc.Document
	Dim oSheets As Inventor.Sheets = oDDoc.Sheets
	For Each oSheet As Inventor.Sheet In oSheets
		Dim oViews As DrawingViews = oSheet.DrawingViews
		If oViews.Count = 0 Then Continue For
		For Each oView As DrawingView In oViews
			If oView.DesignViewAssociative = False Then
				Try
					oView.SetDesignViewRepresentation(oView.DesignViewRepresentation, True)
				Catch
					Logger.Error("Error setting DVR as Associative in view named:  " & oView.Name)
				End Try
		Next 'oView
		oSheet.Update
	Next 'oSheet
	oDDoc.Update
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
NikelARH4K2
That works beautifully thank you! i am going to tweak it to update all sheet before running the sub because if you dont Inventor crashes on my end
but once i update all the sheets it does exactly what i needed
thank you!
