Flat projection incl. description by iLogic
ThomasCassan
ThomasCassan
Hi Buddies!!
I am looking for a way to insert a flat projection via iLogic and display the view text. It should say "ABWICKLUNG/FLAT PROJECTION" and the scale.
is there someone who can help me please??
thx a lot!!
Lg
Thomas C.
Sergio.D.Suárez
Hi, try this code, I think it should work. Select the view you want to change its label
oView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Seleccione Vista")
If oView Is Nothing Then Exit Sub
oView.Label.Formattedtext = "ABWICKLUNG/FLAT PROJECTION ( <DrawingViewScale/> )"
oView.Showlabel =True
 I hope this helps, Regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
ThomasCassan
Hi Sergio
looks great man - thx so far
would it be possible to let the rule create the flat projecten due to click on a view in the drawing???
cheers and thx in advance
Tom
