fitting points on a spline
johnteng00
johnteng00
Hi guys,
First I have created a PlanarSketch, then I have tried to create a SketchSpline by fitting a group of points. I have got the spline created in PlanarSketch object, however the fitting points are also shown on the spline. could anyone tell me how I can delete those fitting points, or at least don't show those fitting points?
thanks
Eric
I don't think you can get rid of the display of the
fit points.  You can't delete them because that will change the shape of
the curve.
Brian Ekins
Autodesk Inventor API Product Designer
href="http://blogs.autodesk.com/modthemachine">http://blogs.autodesk.com/modthemachine
Hi
guys, First I have created a PlanarSketch, then I have tried to create a
show those fitting points? thanks Eric
johnteng00
thanks brian.
I noitce that I can't delete them. But it is annoy to see that there so many points attached to a simple spline curve. Is there any possiblity to supress the points when showing the spline?
Unfortunately, there's nothing that I know of that
will let you suppress there display.
Brian Ekins
Autodesk Inventor
thanks
brian. I noitce that I can't delete them. But it is annoy to see that there so
with spline, ideally you want the minimum number of points that fit the curve to a specified tolerance. Using all the points you are trying to fit to make the spline is easy, but not the best way to do it. I wrote a macro some time ago that would create a spline with all the points, then remove every other point (except endpoints) iteratively til an error tolerance was met or exceeded.
