First time form
First time form
MKE_Howard
First time form
MKE_Howard
Hi Im searching for a ilogic code that can open a form like this :
iLogicForm.Show("Form")
But it needs to open only the first time de document is open. Is that Possible. I know with the event trigger you can do a lot but I don't know how. Thanks
Gabriel_Watson
You can save a property that acts as a flag of whether or not the rule has been run before. You can set the iLogic trigger to run the rule every time the file is open, but a quick test of the property/flag would tell it has been run before (or the input has been given already).
MKE_Howard
Thanks Galaxybane But I had another problem with that.. Everytime I open my drawing document, the form appear so from the .iam I made this rule and put it in my event trigger. Heres the code if anyone needs it.
If ThisApplication.ActiveDocument Is ThisDoc.Document Then
	iLogicForm.Show("Name Of The Form") 'Type here the name of the form
