FindUsingVector in VB.NET
pveng
Message 1 of 10
pveng
Hello All,
does anybody has an example of the FindUsingVector command in vb.net?
There is already an vba example in a previous post ("FindUsingVector") but it didn't work in vb.net.
I think the issue is that in vb.net all arrays are 0 based but the FindUsingVector command needs a 1 based array for the ObjectTypes().
Autodesk help:
ComponentDefinition.FindUsingVector( OriginPoint As Point, Direction As UnitVector, ObjectTypes() As SelectionFilterEnum, [UseCylinder] As Boolean, [ProximityTolerance] As Variant, [VisibleObjectsOnly] As Boolean, [LocationPoints] As Variant ) As ObjectsEnumerator
Thanks in advance
pveng
Replies (9)
Message 2 of 10
adam.nagy
Autodesk Support
Autodesk Support
I don't think that's the issue because in VBA using an array with lower bound 0 works fine.
I guess you are referring to this code?
http://forums.autodesk.com/t5/Inventor-Customization/FindUsingVector/td-p/3772145
You can reproduce the problem with a much simpler code as well, of course. My sample code also contains the solution, which is late-binding:
Sub FindUsingVector_Test
  Try
    Dim oApp As Application = GetObject(, "Inventor.Application")
    Dim oPartDoc As PartDocument
    oPartDoc = oApp.ActiveDocument
    Dim oTG As TransientGeometry
    oTG = ThisApplication.TransientGeometry
    Dim oPoint As Point
    oPoint = oTG.CreatePoint()
    Dim oUV As UnitVector
    oUV = oTG.CreateUnitVector(0, 0, 1)
    Dim oFilter(0) As SelectionFilterEnum
    oFilter(0) = SelectionFilterEnum.kPartFaceFilter
    ' a) Early-binding: if you use this then
    ' FindUsingVector will throw a DISP_E_BADCALLEE error
    'Dim oPartDef As PartComponentDefinition
    ' b) Late-binding: if you use this then
    ' FindUsingVector works fine
    Dim oPartDef As Object
    oPartDef = oPartDoc.ComponentDefinition
    ' In case of early-binding this throws DISP_E_BADCALLEE error
    oPartDef.FindUsingVector(oPoint, oUV, oFilter)
  Catch ex As Exception
    MsgBox(ex.Message)
  End Try
End Sub
Still, this issue should not happen, so I logged it in our database: id 1516333
Cheers,
Adam Nagy
Autodesk Platform Services
Message 3 of 10
pveng
OK, thank you for your help.
Message 4 of 10
Richard.MM
I have a similar problem but in the Assembly.
My code  also return error DISP_E_BADCALLEE.
There is a solution for assembly?
Part of the code see below.
Thank you
Richard M.
Dim asmDoc As AssemblyDocument
asmDoc = m_inventorApp.ActiveDocument
Dim oAsmCompDef As AssemblyComponentDefinition
 oAsmCompDef = asmDoc.ComponentDefinition
 Dim oEdge As ObjectCollection
 oEdge = oAsmCompDef.FindUsingVector(circ1.Center, Unit_vector_x, filtr_new_hrana, True, 10, True)
Message 5 of 10
adam.nagy
Autodesk Support
Autodesk Support
HI Richard,
Did you try the same solution as shown in the above code? - i.e. replace ...
... with ...
Dim oAsmCompDef As Object
Cheers,
Adam Nagy
Message 6 of 10
Richard.MM
Yes, I tried it, but then it returned an error HRESULT: 0x80004001 (E_NOTIMPL).
Message 7 of 10
adam.nagy
Autodesk Support
Autodesk Support
Which Inventor version are you using?
Adam Nagy
Message 8 of 10
Richard.MM
Inventor Professional 2014
Build: 246, Release: 2014 SP2 Update3
Message 9 of 10
HermJan.Otterman
Thanks Adam, this helps but....
I want to find the intersection of a line and a circular edge...
the circular edge is of a hole in a part and the line is a sketch line on that face.
my line intersects at two points, but only the first gets listed (in the Locationpoints)
I also tried FindUsingRay, but still can't find my second intersectionpoint with the circular edge.
how can I find that second intersection point?? (or the coordinates)
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
Message 10 of 10
chandra.shekar.g
Autodesk Support
Autodesk Support
@HermJan.Otterman,
Can you please provide sample inventor file to investigate which is having circle with 2 intersection of line? please make sure that files are non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
