FindUsingRay in C#
FindUsingRay in C#
FindUsingRay in C#
In FindUsingRay method, how can I access m_FoundEnts items types? My goal is to find the type of each item in the collection so I can't manually cast them (I don't know what they are yet) . please look at the same code in VBA which works.
Call oface.SurfaceBody.FindUsingRay(oVertex.Point, normalVector.AsUnitVector, 0, m_FoundEnts, m_LocPoints, False)
    If m_FoundEnts.Count <> 2 Then
       'do something
    If Not ((TypeOf m_FoundEnts.Item(2) Is Vertex)) Then
        'do something else
//these don't work
m_FoundEnts[2].Type(); //Type() does not exist for items.
//returns null for objectOfIntrest
ObjectsEnumerator objectOfIntrest = (ObjectsEnumerator)m_FoundEnts[2];
if (objectOfIntrest.Type == ObjectTypeEnum.kVertexObject) {}
JaneFan
Hello @Anonymous,
Please try using var to define the type unknown objects.
var test1 = m_FoundEnts[2];
if(test1.Type == Inventor.ObjectTypeEnum.kVertexObject)
Jane Fan
Inventor/Fusion QA Engineer
@JaneFan
as you can see I don't have Type() property for item numbers. In debug mode I can see that there is a public Type() property for this object but I cant use it! see below
JaneFan
Yes, so please put the object to a var type variant and then get type of the variant.
Jane Fan
thats what ive done in the first photo I'd sent. does not work. there is no Type() methods in intellisense.
JaneFan
I see. Type property here is run time property.
I can't find a better way but using try cast and do something in such case:
try
Vertex testss = (Vertex)m_FoundEnts[2];
catch(Exception e)
//do something else
Jane Fan
