Finding the native face/edge from proxy face/edge in weldment
Raider_71
Raider_71
Hi, I am having an issue finding the native face or edge object from a Weldment assembly if the weldment has machining features present. If no machining features are present then it works fine. It makes sense as the machining would create an alternative body that is represented in the assembly and which is different to the original part surface body. How do I translate the selected face or edge (or any object for that matter) to the relevant part face or edge?
In this case, I have the user select a Planar face at assembly level. The app must then find the face in the part document and create a part sketch.
As I said this works in a normal assembly or a Weldment with no machining features on the part. As soon as any features are present the sketch creation fails.
My simplified code:
        Dim oAssyDoc As AssemblyDocument = oApp.ActiveDocument
        Dim oFaceProxy As FaceProxy = oApp.CommandManager.Pick(SelectionFilterEnum.kPartFacePlanarFilter, "Select Planar Face")
        Dim oOccurrence As ComponentOccurrence = oFaceProxy.ContainingOccurrence
        Dim oPartDoc As Inventor.PartDocument = oOccurrence.ReferencedDocumentDescriptor.ReferencedDocument
        Dim oPartCompdef As Inventor.PartComponentDefinition = oPartDoc.ComponentDefinition
        Dim oSketch As PlanarSketch = oPartCompdef.Sketches.Add(oFaceProxy.NativeObject)
WCrihfield
Just thinking out loud here...but maybe do it in reverse.  What I mean is get the NativeObject from the FaceProxy object to a variable (As Face) first.  Then get the Face.Parent.Parent (Face.Parent is a SolidBody, SolidBody.Parent or SurfaceBody.ComponentDefinition) to get the ComponentDefinition (which can be set as the value of a PartComponentDefinition type variable).  This route might work, while the other route might fail.  Just a thought.
Wesley Crihfield
(Not an Autodesk Employee)
Raider_71
@WCrihfield  thanks for your reply.
I have done some more digging and came across the following which seems to work just fine.
First, do a check to see if the body was overwritten. If it was then you use the GetSorceFace method to get to the part face and then create the sketch.
        If oOccurrence.HasBodyOverride Then
            oFace = oFaceProxy.NativeObject.GetSourceFace
        Else
