Find points were used to create an UCS
ngocson8335
ngocson8335
Hello everyone,
I created a UCS by 3 edge points in a part. Now I would like to specify back which edge points that I used to create that UCS.
Thank you.
Ngoc Son
Autodesk User
J-Camper
You have to look at the UCS Definition.  There is a method: GetByThreePoints :
Dim PickThis As UserCoordinateSystem = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kUserCoordinateSystemFilter, "Select UCS")
If IsNothing(PickThis) Then Exit Sub ' If nothing gets selected then we're done
Dim Origin, xPoint, yPoint As Object
PickThis.Definition.GetByThreePoints(Origin, xPoint, yPoint)
Logger.Trace(CType(Origin.Type, ObjectTypeEnum).ToString)
Logger.Trace(CType(xPoint.Type, ObjectTypeEnum).ToString)
Logger.Trace(CType(yPoint.Type, ObjectTypeEnum).ToString)
Although, when I picked edge midpoints the Object returned in the edge it self, but Endpoints actually return as vertex objects.
