I have come up with a routine that handles the majority of cases, I do expect to see issues when there are user cutouts and will just have to require those be manually developed until I can come up with something better. Since I asked for solutions, seems only fair I share mine; perhaps someone can provide a more elegant solution than this. Here's the gist of the code, it does not contain all necessary declarations and will need expected model data to function so don't expect to be able to copy, paste & run.
Dim oMin As Double
Dim oMax As Double
Dim oStart() As Double = {}
Dim oEnd() As Double = {}
Dim PointList As New ArrayList
Dim LeftList As New ArrayList
Dim RightList As New ArrayList
Dim MinX As Double
Dim MaxX As Double
Dim MinY As Double
Dim MaxY As Double
Dim MidBox As Point2d
Dim NoSides As Integer = 6
Dim NoSections As Integer = 2
Dim StartFlat As Integer = 1
For i = 1 To NoSides / NoSections 'collect faces into array
oFaceColl(i) = iLogicVb.Automation.GetNamedEntities(ThisDoc.Document).TryGetEntity("Flat " & CStr(i + StartFlat - 1))
PointList.Clear
LeftList.Clear
RightList.Clear
For j = 1 To oFaceColl(i).Edges.Count 'set loop for each edge found
oFaceColl(i).Edges.Item(j).Evaluator.GetEndPoints(oStart, oEnd)
oPntChk(1) = oTG.CreatePoint(oStart(0), oStart(1), oStart(2)) 'get start point of current edge
oPntChk(2) = oTG.CreatePoint(oEnd(0), oEnd(1), oEnd(2)) 'get endpoint of current edge
oChkPnt(1) = oSketch.ModelToSketchSpace(oPntChk(1)) 'convert to sketch 2d
oChkPnt(2) = oSketch.ModelToSketchSpace(oPntChk(2)) 'convert to sketch 2d
For k = 1 To 2
Found = False
For l = 1 To PointList.Count
If oChkPnt(k).IsEqualTo(PointList.Item(l - 1)) Then Found = True
Next
If Not Found Then PointList.Add(oChkPnt(k)) 'add non-duplicated points to list
Next
Next
'sort points
MinX = PointList.Item(0).X
MaxX = PointList.Item(0).X
MinY = PointList.Item(0).Y
MaxY = PointList.Item(0).Y
Dim FPoint(NoSides / NoSections, 4)
For j = 1 To PointList.Count - 1 'find extents box of 2D point list
If PointList.Item(j).X < MinX Then MinX = PointList.Item(j).X
If PointList.Item(j).X > MaxX Then MaxX = PointList.Item(j).X
If PointList.Item(j).Y < MinY Then MinY = PointList.Item(j).Y
If PointList.Item(j).Y > MaxY Then MaxY = PointList.Item(j).Y
Next
MidBox = oTG.CreatePoint2d(MaxX - ((MaxX - MinX) / 2), MaxY - ((MaxY - MinY) / 2)) 'Approximate middle of face
'Sort into left/right sides (along x axis)
For j = 0 To PointList.Count - 1
If PointList.Item(j).X < MidBox.X Then LeftList.Add(PointList.Item(j)) Else RightList.Add(PointList.Item(j))
Next
'Left side sort
If LeftList.Count = 2 Then
If LeftList.Item(0).Y < LeftList.Item(1).Y Then
FPoint(i, 1) = LeftList.Item(0)
FPoint(i, 2) = LeftList.Item(1)
Else
FPoint(i, 2) = LeftList.Item(0)
FPoint(i, 1) = LeftList.Item(1)
Else
For j = 0 To LeftList.Count - 1
If LeftList.Item(j).Y = MinY Then
FPoint(i, 1) = LeftList.Item(j) 'find point a min Y position & assign as lower left point
LeftList.RemoveAt(j) 'remove from current list
Exit For 'found it, exit loop
Next
FPoint(i, 2) = LeftList.Item(0) 'temp assign first point in updated list
For j = 1 To LeftList.Count - 1 'search for left most X position
If LeftList.Item(j).Y > FPoint(i, 2).Y Then FPoint(i, 2) = LeftList.Item(j)
Next
'Right side sort
If RightList.Count = 2 Then
If RightList.Item(0).Y > RightList.Item(1).Y Then
FPoint(i, 3) = RightList.Item(0)
FPoint(i, 4) = RightList.Item(1)
Else
FPoint(i, 4) = RightList.Item(0)
FPoint(i, 3) = RightList.Item(1)
Else
For j = 0 To RightList.Count - 1
If RightList.Item(j).Y = MaxY Then
FPoint(i, 3) = RightList.Item(j) 'find point a max Y position & assign as lower left point
RightList.RemoveAt(j) 'remove from current list
Next
FPoint(i, 4) = RightList.Item(0) 'temp assign first point in updated list
For j = 1 To RightList.Count - 1 'search for right most X position
If RightList.Item(j).X > FPoint(i, 4).X Then FPoint(i, 4) = RightList.Item(j)
Next
For j = 1 To 4
oSketch.SketchPoints.Add(FPoint(i, j))
Next
Next
Autodesk Inventor Certified Professional
