Find intersection point between line segment and workplane
I have to create a hole (extrude) in a wall part in my assembly document where a stack will be installed.
To determine where, I verify if a line segment pass through the wall (XY Plane).
But I get an error with the command: IntersectWithLine
Here's my code:
Public Function IntersectionPoint(ByVal app As Inventor.Application,
                                      ByVal wp As Inventor.WorkPlane) As Inventor.Point
        Dim oTransGeom As Inventor.TransientGeometry = app.TransientGeometry
        Dim startPoint As Inventor.Point = oTransGeom.CreatePoint(Me.StartVertex.X, Me.StartVertex.Y,
        Me.StartVertex.Z)
        Dim endPoint As Inventor.Point = oTransGeom.CreatePoint(Me.EndVertex.X, Me.EndVertex.Y,
        Me.EndVertex.Z)
        Try
            Dim pt1 As Inventor.Point = oTransGeom.CreatePoint(startPoint.X, startPoint.Y, startPoint.Z)
            Dim pt2 As Inventor.Point = oTransGeom.CreatePoint(endPoint.X, endPoint.Y, endPoint.Z)
            Dim vector As Inventor.Vector = pt1.VectorTo(pt2)
            Dim lineSeg As Inventor.LineSegment = oTransGeom.CreateLineSegment(pt1, pt2)
            Dim pt As Inventor.Point = wp.Plane.IntersectWithLine(lineSeg)  'THIS LINE GIVE ME AN ERROR
            Return pt
        Catch ex As Exception
            Throw New Exception(ex.Message, ex)
        End Try
    End Function
Thanks for help.
Pascal
xiaodong_liang
Autodesk Support
Autodesk Support
I created a standalone EXE and tested the code below. It works well. The attached screenshot shows it. I suspected the failure at your side occurs in specific scenario.
    Private Sub test()
        Dim oApp As Inventor.Application
        Try
            oApp = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application")
        End Try
        Dim oPartDoc As PartDocument = oApp.ActiveDocument
        Dim wp As Inventor.WorkPlane = oPartDoc.ComponentDefinition.WorkPlanes("XY Plane")
        IntersectionPoint(oApp, wp)
    End Sub
    Public Function IntersectionPoint(ByVal app As Inventor.Application, _
        Dim startPoint As Inventor.Point = oTransGeom.CreatePoint(0, 0, 1)
        Dim endPoint As Inventor.Point = oTransGeom.CreatePoint(0, 0, -1)
        Try
            Return pt
        End Try
    End Function
Best regards,
Xiaodong Liang
Developer Consultant
Autodesk Developer Technical Services
I do that in an AssemblyDocument.  So, my ActiveDocument is not a PartDocument but an AssemblyDocument.
Maybe that is the reason why I get an error?
Is it possible to do that in an Assembly document?
Thank you,
Pascal
staff7NWEE
Is there another solution to this problem yet?
