Find Folder using Ilogic
Andrew_Burnett
Andrew_Burnett
Looking for some help with some code to find a job folder on our network using Ilogic or VBA code.  We use a folder structure that contains the job number and a description of the job.  The description varies by job.  The folder has the job number - description (Example: 123456 is the job number.  The folder name is 123456 - pipe parts)  In the Inventor file the user enters the job number.  I want to use the job number the user entered to find the correct job folder and use it as the save location in my Ilogic rule.  I have tried a couple codes but none will find the folder.  Any help would be greatly appreciated.
JelteDeJong
is this what you are looking for?
Dim mainPath As String = "c:\temp\"
Dim mainDirectory As IO.DirectoryInfo = New IO.DirectoryInfo(mainPath)
Dim jobNumber = InputBox("Enter the job number", "Jon number", "")
Dim jobDirectoryName As String = ""
For Each jobDirectory As IO.DirectoryInfo In mainDirectory.GetDirectories()
	If (jobDirectory.Name.StartsWith(jobNumber)) Then
		jobDirectoryName = jobDirectory.FullName
Next
If (String.IsNullOrEmpty(jobDirectoryName)) Then
	MsgBox("Directory with jobnumber " + jobNumber + " not found!")
MsgBox(jobDirectoryName)
Jelte de Jong
Blog: hjalte.nl - github.com
Andrew_Burnett
Exactly what I was looking for.  Thank you for the help.  It is greatly appreciated.
Andrew_Burnett
I found another issue with how we structure stuff.  We also use the vault for storing files.   The question I have is the structure of the vault contains the customer name and then the job number.  example structure:  C:\Work\Jobs\Customer name\Job Number.  Is there a way for me to search through all of the customer folders to find the job number folder that matches what the user has entered?  Any help would be greatly appreciated.  The last code worked great for finding it on the network.
Thank you
Andrew_Burnett
I figured it out.  needed to sort down through the directories.  Here is the code I came up with.
Dim mainPath As String = "c:\Work\Jobs\"
Dim jobNumber = InputBox("Enter the job number", "Job number", "")
	For Each jobDirectory2 As IO.DirectoryInfo In jobDirectory.GetDirectories()
		If (jobDirectory2.Name.StartsWith(jobNumber)) Then
		jobDirectoryName = jobDirectory2.FullName
Next
Next
