Find and list with ilogic
jletcher
Advisor Advisor
Message 1 of 13
jletcher
Trying to have ilogic find parts in an assembly that start with 900C7 so I can link the to a cell in excel showing the QTY and the LENGTH..
Right now I am just trying to get ilogic to find and list them then I know I can move to the next step..
Example:
 900C71.250
 900C72.125
 900C7A.750
 900C7P1.1875
 And many more.
  Here is what I have but it keeps posting the NOTHING message box. I have a few of the parts in the assembly and a few none 900C7 parts.
Dim openDoc As Inventor.Document
Dim docFile As Inventor.Document
Dim assemblyDoc As AssemblyDocument
Dim partOcc As ComponentOccurrence
Dim FNamePos As Long
Dim docFName As String
Dim oList As Collection = New Collection
openDoc = ThisApplication.ActiveDocument
If openDoc.DocumentType = kAssemblyDocumentObject Then
    assemblyDoc = openDoc
    assemblyDef = assemblyDoc.ComponentDefinition
	Else
MessageBox.Show("You must have a valid Assembly document open before using this code!", "File Type Mismatch!",MessageBoxButtons.OK,MessageBoxIcon.Exclamation)
For Each docFile In openDoc.AllReferencedDocuments
If (Left ( docFName, 6) = "900C7P") Then
        oList.Add(docFName)
Next
If oList.Count = 0 Then
    MessageBox.Show("NOTHING")
Else
    'print oList
    Dim sTotal As String = "Found:  " & oList.Count
    For Each st As String In oList
        sTotal += vbNewLine & st
    Next
    MsgBox(sTotal)
 Here is a screen shot of the excel file not sure if you need it but you may get a better idea what I am trying.
  Thanks for any help..
Replies (12)
Message 2 of 13
ekinsb
What you want to do is surely possible. There are a couple of reason why your existing code isn't behaving as you expect.  First, I don't see where you're setting the value of docFName so the If statement where you're looking for a specific file is always comparing against an empty string.  Second depending on how you set docFName you need to be careful that it's just the file name and the not full filename (path and file).  This is because in your comparison statement you're assuming it's just the file name with no path.
In many cases like this it's easier to write the initial code in VBA where you have some good debugging tools and then move it to iLogic once you have the basic logic working.
Brian Ekins
Mod the Machine blog
Message 3 of 13
jletcher
I recieved an email asking for more information on this but I don't see any questions..
 Case 08979816
 What are more information do you need?
Message 4 of 13
Hey James,
Brian already pointed you to the FullFileName property of the document object.
You would have to use docFile.FullFileName to get this in your document enumeration.
The problem with this is that the FullFileName property includes the complete path to the document
plus the filename.
So you would have to substract the path from the FullFileName property to get the filename.
As an alternative you could use the displayName property from the document object if your displayName is the
same as the filename.
Hope that helps
All the best
Falk
P.S.: I just looked at some code I have and I solved it with using
Dim DocPath As String = ThisDoc.Path & "\"
I´m not sure if docFile.Path would give you the path only.
Cheers
Message 5 of 13
ekinsb
Falk is correct that the full document name is returned.  There is a very easy way to extract the full filename from that.  You can use the CommandManager.GetFullFileName method.  There are a few functions on the CommandManager object to make working with file names a bit easier.
Brian Ekins
Message 6 of 13
jletcher
Not sure I would need full path and all, is the a way to use just the iproperty part number?
 So when I am in an assembly run the rule it would list them and be able to extract information from them to fill in the spread sheet?
  Is autodesk working on a help book for just ilogic? Trying to use API (VBA) code is real hard to figure what works and not work in ilogic.
But it could be just me self taught on VB an C++ so not the best at it. And without a sample it is really hard for me to grasp but I will not quit LOL.
Message 7 of 13
I´m exactly on the same path James,
I started out with just iLogic 12 months ago and figured after a while that VB.net works too in
iLogic so I grabbed a book for VB.net and started to learn the basic concepts.
It´s a tough path with iLogic cause you don´t have a debugger for iLogic.
Fortunately I was able with the book on VB.net and examples from the internet to get around
most problems.
I´m still learning VB.net and Inventor API and I wouldn´t consider myself an expert.
But hey, it´s getting better everyday 🙂
One day I will make the transition to plugins with Visual Studio Express so I can get rid of the limitations.
@Brian:
That´s very useful info on the command manager. I just checked (still on 2012) and couldn´t find anything in the programming help about the GetFullFilename method. Is this something new for 2013/2014?
All the best
Message 8 of 13
xiaodong_liang
Autodesk Support
Autodesk Support
Hi James,
Firstly, I believe Brian meant "FileManager.GetFullFileName".
About your question, you could get the iProperties from the component document directly when you iterating the referenced documents, e.g.
  Dim oIProInEachRefDoc
  oIProInEachRefDoc = docFile.PropertySets("Design Tracking Properties").Item("Part Number")
  Dim oPartNo
  oPartNo = oIProInEachRefDoc.Value
  MessageBox.Show(oPartNo)
Next
iLogic wraps some functions of Inventor API to make it easier for some end users. In this case,
is similar to
  iProperties.Value("Project", "Part Number")
But the later can only work for the current document.
Message 9 of 13
xiaodong_liang
Autodesk Support
Autodesk Support
Hi falkmassmann,
The API helps shows FileManager.GetFullFileName is Introduced in Inventor version R11.
Hi James,
As falkmassmann has practised, it is the best way to debug in VB.NET on the complex code firstly and copy it to iLogic. As you may have known, we have a "My First Plugin" course for the newbie of VB.NET. It is a good material to get started with API in VB.NET
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=17324828
In addition,we have a lot of training videos on the basic topics of Inventor API.
http://adndevblog.typepad.com/manufacturing/2013/05/api-webcast-archive.html
e.g. about the PropertySets in the code I provided in the last message, you could find the introduction in this video:
http://download.autodesk.com/media/adn/Autodesk_Inventor_API_Module2_Common_Document_Functionality_1...
Message 10 of 13
jletcher
xiaodong,
    Yes I understand that but when the help files don't work I can't find what I think I might need or look up to see.
 This is why I have to post here and hope someone sees that I am trying to do this with ilogic and post the fixed code for my issue not send me to a help that don't work..
  And seeing not everything in the VBA works with ilogic but you have to know what to take out what to change.
  Why not work on a ilogic help file instead?
Message 11 of 13
Not sure if you got an answer to this yet but here's what I got and it seems to be working. I didn't put in the code to check if the active doc is an IAM or not. I figured if it was going to be a local rule in an IAM it's not really needed. But if you are planning to write it as an external rule then you will need it. Hope this helps.
Dim oDoc As Inventor.Document = ThisDoc.Document
For Each docFile In oDoc.AllReferencedDocuments
    'MessageBox.Show(docFile.DisplayName)
    Dim FileNameTemp As String = (Left (docFile.DisplayName, 6))
    If FileNameTemp.ToUpper = "900C7P" Then
        oList.Add(docFile.DisplayName)
Next
Else
    'print oList
    Next
    MessageBox.Show(sTotal)
Message 12 of 13
xiaodong_liang
Autodesk Support
Autodesk Support
Hi James,
May I know whether my code works, or the code danvang posted in message 12 helps you?
We have iLogic help on Autodesk wiki. It introduces iLogic basic and the functions. So, if the existing functions could meet the requirements, you could find help on wiki.
But the functions are limited. For some advanced / specific requirements, you have to use Inventor API . To some extent, iLogic is just a sub-set of Inventor API. The codes in iLogic is nearly the same to that in VB.NET. That is why we suggested you test in VB.NET and paste it to iLogic.
In a word, iLogic is just a tiny environment of coding with limited wrapped functions. So Inventor API help can apply to iLogic as well when you need advanced/specific functions. particularly, when the code/workflow is complex, it is highly required to debug, instead of running iLogic directly. otherwise, it will very hard to address problem. So, I still suggest you take a look at our material ""My First Plugin" to get some ideas how to work with VB.NET + Visual Studio. It will be of much help for your programming.
Message 13 of 13
jletcher
danvang,
    Thank you that worked.
Now to write the rest of the code....
xiaodong,
   No your code did not work it gave errors when ran. Was this the whole code or was this to be added to my code?
