FileUI OnSaveAsDialog event not triggered
I'm trying to capture the first save and save as dialogs to fill in a file name for the user. However, when I'm using the event watcher to capture the event, it doesn't fire. This effect occurs when I'm using my own application as well. I'm using Inventor professional 2017 on a Windows 10 computer (have tried switching to Windows 8 compatibility mode already). Does anyone have a suggestion for me? Thank you in advance for your help!
Rik Borger
petervoegeli
Owner2229
You have to set "Embed Interop Types" to False"
http://modthemachine.typepad.com/my_weblog/2012/07/set-embed-interop-types-to-false-to-avoid-problem...
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
