File Dialog set initial directory not working
I've taken a sample from here to create a dialog box:
https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2018/ENU/Inventor-API/files/Fi...
But I'm finding that setting the InititalDirectory is not working as I expected it to. When the file dialog opens I'm presented with the last directory I was in, rather than the one specified in the code.
Am I missing something or misunderstanding what this property means?
InititalDirectory
Property that gets and sets the directory that will be used when the dialog is initially displayed.
Curtis_Waguespack
Hi @Anonymous,
I think this is just an ongoing bug (see link), but I don't know of a good work around.
https://forums.autodesk.com/t5/inventor-customization/file-dialog-initial-directory-stuck-on-workspace/m-p/6883307#M70261
I hope this helps.
Curtis
Boohoo!! Smiley Sad that will be that project parked then
Thanks for the info @Curtis_Waguespack
