Faulty MS Exсel <-> Inventor Part table
Hi, Everyone
Please help to localize problem I have on some particular PCs.
Problem: none of two actions coded below works.
First action (see line with comment “'change title”) is supposed to rename the title of the most-right column in the Configuration Factory Table.
The next action (just after the line) is supposed to add new column in the Configuration Factory Table.
On other PCs the result is «as expected» …on «these» - no results (no errors … nothing).
I suspect that some component connecting Inventor and MS Excel is to blame but which and how to fix this?
Please help.
ipartDoc = m_inventorApplication.ActiveDocument
                opartfactory = ipartDoc.ComponentDefinition.iPartFactory
                Dim tcc As Integer = 0
                Dim dRowP As iPartTableRow
                Dim oWorksheet As Excel.Worksheet
                dRowP = opartfactory.DefaultRow
                ' save default row
                inewColumnIndex = GetColumnIndex(opartfactory, "Title [Summary]")
                If inewColumnIndex = -1 Then
                    Dim oFactory As iPartFactory
                    oFactory = ipartDoc.ComponentDefinition.iPartFactory
                    oWorksheet = oFactory.ExcelWorkSheet
                    tcc = oFactory.TableColumns.Count + 1
                    Debug.Print(oFactory.TableColumns.Count)
                    oWorksheet.Cells(1, oFactory.TableColumns.Count) = "Changed" 'change title
                    oWorksheet.Cells(1, tcc) = "Title [Summary]"
                    For ir As Integer = 2 To oFactory.TableRows.Count + 1
                        oWorksheet.Cells(ir, tcc) = "new"
                    Next
                    Dim oWorkbook As Excel.Workbook
                    oWorkbook = oWorksheet.Parent
                    Dim oXlsApp As Excel.Application
                    oXlsApp = oWorkbook.Parent
                    oWorkbook.Save()
                    oWorkbook.Close()
                    oWorksheet = Nothing
                    oWorkbook = Nothing
Dennis.Ossadnik
Autodesk Support
Autodesk Support
Hi maxstel,
maybe this could solve the problem if these PC's are using W7 64-bit with Excel 2010.
http://usa.autodesk.com/getdoc/id=TS14079866
regards
Dennis
Dennis Ossadnik
Senior Technical Support Specialist
