Fast way to change line weight or layer for selected views in Inventor Drawing using API
Michal_Lek
Message 1 of 1
Michal_Lek
Hello everybody,
I would like to modify all lines' widths of selected drawing views. My colleague have noticed that doing it thorough selection of a referenced component in the browser pane and using Properties... command is the fastest. In this GUI approach a form appears where By layer checkbox can be deactivated and Line Weight can be selected. The lines are modified almost instantly also for heavy models with lots of lines. Is there a way to achieve similar performance using API?
What I've tried is to select all the segments of DrawingCurves and insert them into an ObjectCollection. Than using Sheet.ChangeLayer method I've moved lines to a layer with thinner line. This unfortunately takes much more time, up to few minutes for bigger assemblies.
This is what I've tried, but the performance wasn't satisfying.
Public Sub drawingChangeLayer()
    Dim oDrawDoc As DrawingDocument
    Set oDrawDoc = ThisApplication.ActiveDocument
    Dim oSheet As sheet
    Set oSheet = oDrawDoc.ActiveSheet
    Dim curveObColl As ObjectCollection
    Set curveObColl = ThisApplication.TransientObjects.CreateObjectCollection
    Dim oselSet As SelectSet
    Set oselSet = oDrawDoc.SelectSet
    Dim oDrView As DrawingView
    For Each oDrView In oselSet
        Dim oCurve As DrawingCurve
        For Each oCurve In oDrView.DrawingCurves()
            Dim oSeg As DrawingCurveSegment
            If Not oCurve.Segments Is Nothing Then
                For Each oSeg In oCurve.Segments
                    Call curveObColl.Add(oSeg)
                Next
        Next
    Next
    Dim lay As Layer
    Set lay = oDrawDoc.StylesManager.Layers.Item(226)
    Call oSheet.ChangeLayer(curveObColl, lay)
End Sub
  Thanks in advance.
Michal
Replies (0)
