Fail to install
Fail to install
Message 1 of 1
Fail to install
Hello
I previously had Inventor 2016 installed on my desktop but needed to use the restore option to get rid of a virus that McAfee failed to. I have Windows 10. When I start my installation of Inventor, it gets down to a 1hr left then stops. This is the last few lines of my installation log.
016/8/20:11:58:25            Pat         PAT        Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\Pat\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2016/8/20:11:58:25          Pat         PAT        Install    Microsoft Visual C++ 2012 Redistributable (x64) Update 4                Succeeded
2016/8/20:11:58:26          Pat         PAT        Download           Play        CMILL                http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/CMILL...
2016/8/20:12:00:23          Pat         PAT        Download           Aborted               CMILL                http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/CMILL...
2016/8/20:12:00:23          Pat         PAT        Install    Autodesk® Material Library 2016 - Low Image Library       Failed                Download Failed, Installation aborted, Result=1603
Any sujjestions
Replies (0)
