Fail to install inventor 2015
Hi.
I need to install inventor 2015 on my PC which is used in my college ( YSU ) to do assignments and training for my college classes but it failed every time after about 45 minutes of installation.
I'm using a laptop with specification as attached picture.
Please advice.
Thanks.
frederic.vandenplas
Probably you have a higher .NET framework then Expected for the installer.
We had several installation problems with 2015, so we removed .NET framework 4.5/4.2/4.0...
And then it installed without problems
Inventor 2015 whishes to install .NET 4.0 and for us that was solved by doing that.
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
