Faces, Assembly Constrains and so on...
Hi.
I have the follow situation: Two parts inserted into a assembly file. In each part I have an assembly constrain join them. Now, I'd like automatically get the Faces where the constrains are there.
For example: the two parts are cubes. One cube has six sides. So, I want get the face index where is there the constrain.
How can I do it? Someone has an idea?
Mac
The entities on the part that the constraint is
tied to are available through the EntityOne and EntityTwo properties of the
AssemblyConstraint object.  The code below is a simple example that
highlights the entities associated with each constraint.
Public Sub
ShowConstraintFaces()
    ' Get a reference to the assembly
component definition.
    Dim oAsmCompDef As
AssemblyComponentDefinition
    Set oAsmCompDef =
ThisApplication.ActiveDocument.ComponentDefinition
    ' Get a reference to a particular part.  This just
gets
    ' the first one in the browser.
Dim oOcc As ComponentOccurrence
    Set oOcc =
oAsmCompDef.Occurrences.Item(1)
Create a highlight set to use in displaying the entities
used for the constraints.
    Dim oHS As
HighlightSet
    Set oHS =
ThisApplication.ActiveDocument.HighlightSets.Add
    Call
oHS.SetColor(0, 255, 0)
    ' Iterate
through each of the constraints on the occurrence.
    Dim
oConstraint As AssemblyConstraint
    For Each oConstraint In
oOcc.Constraints
        ' Highlight the
two entities used for the
constraint.
        oHS.AddItem
oConstraint.EntityOne
        oHS.AddItem
oConstraint.EntityTwo
        MsgBox
"Entities for constraint """ & oConstraint.Name & """ are
highlighted."
        oHS.Clear
Next
End Sub
-Brian
Hi.
Mac
