Extracting the Angles of An Occurrence and using them to place a new copy of it
cencinaNB2ET
cencinaNB2ET
I have tried reading all posts relating to extracting the angles iproperties from an occurrence and then using them to transform a new matrix that is then used to place another copy of the same occurrence grounded in the exact same position.
Extracting the angles seem to work first with this code:
https://adndevblog.typepad.com/manufacturing/2013/01/inventor-eulerian-angles-of-assembly-component....
Modified to use within ilogic:
Imports System
Imports System.Math
Sub Main()
Dim oDoc As AssemblyDocument
oDoc = ThisDoc.Document
Dim oOcc As ComponentOccurrence
Dim oOc_Name As String
Dim Map As Inventor.NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap()
If RuleArguments.Exists("Component_Name") Then
oOc_Name = RuleArguments("Component_Name")
MessageBox.Show(oOc_Name)
Else
oOc_Name = "Counter - 1.ipt:1"
oOcc = oDoc.ComponentDefinition.Occurrences.ItemByName(oOc_Name)
Dim oMat As Matrix
oMat = oOcc.Transformation
Dim aRotAngles(2) As Double
Call CalculateRotationAngles(oMat, aRotAngles)
Dim Numbers_Store As New ArrayList
Dim i As Integer
For i = 0 To 2
MessageBox.Show(FormatNumber(aRotAngles(i), 5))
Numbers_Store.Add(FormatNumber(aRotAngles(i), 5))
Next i
SharedVariable("Angles") = Numbers_Store
End Sub
Sub CalculateRotationAngles(ByVal oMatrix As Inventor.Matrix, ByRef aRotAngles() As Double)
'Const PI = 3.14159265358979
'Const TODEGREES As Double = 180 / PI
Dim dB As Double
Dim dC As Double
Dim dNumer As Double
Dim dDenom As Double
Dim dAcosValue As Double
Dim oRotate As Inventor.Matrix
Dim oAxis As Inventor.Vector
Dim oCenter As Inventor.Point
oRotate = ThisApplication.TransientGeometry.CreateMatrix
oAxis = ThisApplication.TransientGeometry.CreateVector
oCenter = ThisApplication.TransientGeometry.CreatePoint
oCenter.X = 0
oCenter.Y = 0
oCenter.Z = 0
' Choose aRotAngles[0] about x which transforms axes[2] onto the x-z plane
dB = oMatrix.Cell(2, 3)
dC = oMatrix.Cell(3, 3)
dNumer = dC
dDenom = Sqrt(dB * dB + dC * dC)
' Make sure we can do the division. If not, then axes[2] is already in the x-z plane
If (Abs(dDenom) <= 0.000001) Then
aRotAngles(0) = 0#
Else
If (dNumer / dDenom >= 1#) Then
dAcosValue = 0#
Else
If (dNumer / dDenom <= -1#) Then
dAcosValue = PI
Else
dAcosValue = Acos(dNumer / dDenom)
aRotAngles(0) = Sign(dB) * dAcosValue
oAxis.X = 1
oAxis.Y = 0
oAxis.Z = 0
Call oRotate.SetToRotation(aRotAngles(0), oAxis, oCenter)
Call oMatrix.PreMultiplyBy(oRotate)
' Choose aRotAngles[1] about y which transforms axes[3] onto the z axis
If (oMatrix.Cell(3, 3) >= 1#) Then
dAcosValue = 0#
Else
If (oMatrix.Cell(3, 3) <= -1#) Then
dAcosValue = PI
Else
dAcosValue = Acos(oMatrix.Cell(3, 3))
aRotAngles(1) = Math.Sign(-oMatrix.Cell(1, 3)) * dAcosValue
oAxis.X = 0
oAxis.Y = 1
oAxis.Z = 0
Call oRotate.SetToRotation(aRotAngles(1), oAxis, oCenter)
' Choose aRotAngles[2] about z which transforms axes[0] onto the x axis
If (oMatrix.Cell(1, 1) >= 1#) Then
dAcosValue = 0#
Else
If (oMatrix.Cell(1, 1) <= -1#) Then
dAcosValue = PI
Else
dAcosValue = Acos(oMatrix.Cell(1, 1))
aRotAngles(2) = Math.Sign(-oMatrix.Cell(2, 1)) * dAcosValue
aRotAngles(0) = aRotAngles(0)
aRotAngles(1) = aRotAngles(1)
aRotAngles(2) = aRotAngles(2)
End Sub
Public Function Acos(value) As Double
Acos = Math.Atan(-value / Math.Sqrt(-value * value + 1)) + 2 * Math.Atan(1)
End Function
The Angles are then exported as shared variable back to the rule where the iteration is occurring and the matrix transformation are occurring:
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisDoc.Document
Dim oAsmDef As AssemblyComponentDefinition
oAsmDef = oAsmDoc.ComponentDefinition
Dim iLogicAuto As Object
iLogicAuto = iLogicVb.Automation
Dim Occurrences As ComponentOccurrences
Dim X_Int As Double
Dim Y_Int As Double
Dim Z_Int As Double
Dim oTG As TransientGeometry
oTG = ThisApplication.TransientGeometry
Dim oMatrix As Matrix
oMatrix = oTG.CreateMatrix
Dim oTempMatrix_1 As Matrix
Dim oTempMatrix_2 As Matrix
Dim oTempMatrix_3 As Matrix
Dim oTempMatrix_4 As Matrix
Dim oTempMatrix_5 As Matrix
Dim oTempMatrix_6 As Matrix
Dim oMatrix_1 As Matrix
oTempMatrix_1 = oTG.CreateMatrix
oTempMatrix_2 = oTG.CreateMatrix
oTempMatrix_3 = oTG.CreateMatrix
oTempMatrix_4 = oTG.CreateMatrix
oTempMatrix_5 = oTG.CreateMatrix
oTempMatrix_6 = oTG.CreateMatrix
Dim Location As String
Dim oPart As PartDocument
Dim oPart_Def As PartComponentDefinition
Dim Part_Location As String
Dim Part_Name As String
Dim New_Assembly_Name As String
Dim Angles_Group As New ArrayList
Dim HDPE_Components As New ArrayList
HDPE_Components.Add("Driving Mounting Panel.ipt")
HDPE_Components.Add("Steering Wheel.ipt")
HDPE_Components.Add("Wave Bridge Plastic Panel.ipt")
HDPE_Components.Add("Sun Panel.ipt")
HDPE_Components.Add("Counter.ipt")
'HDPE_Components.Add("Flower Infill Panel.ipt")
For Each oOcc In oAsmDef.Occurrences
'On Error Resume Next
If HDPE_Components.Contains(iProperties.Value(oOcc.Name, "Custom", "PFN")) AndAlso oOcc.DefinitionDocumentType = kPartDocumentObject Then
X_Int = FormatNumber(oOcc.Transformation.Translation.X, 2, vbTrue, vbFalse, vbFalse)
Y_Int = FormatNumber(oOcc.Transformation.Translation.Y, 2, vbTrue, vbFalse, vbFalse)
Z_Int = FormatNumber(oOcc.Transformation.Translation.Z, 2, vbTrue, vbFalse, vbFalse)
oPart = oOcc.ReferencedDocumentDescriptor.ReferencedDocument
Part_Location = oPart.FullDocumentName
Part_Location = Left(Part_Location, InStrRev(Part_Location, "\"))
Part_Name = Right(oPart.FullDocumentName, Len(oPart.FullDocumentName) -Len(Part_Location))
Part_Name = Left(Part_Name, Len(Part_Name) - 4)
New_Assembly_Name = Part_Location + Part_Name + ".iam"
'MessageBox.Show(New_Assembly_Name)
'iLogicAuto.RunExternalRule(oPart, "Update Component")
'iLogicAuto.RunExternalRule(oPart, "HDPE Part to Assembly")
Map.Add("Component_Name", oOcc.Name)
iLogicAuto.RunExternalRuleWithArguments(oAsmDoc, "Extract Angles", Map)
Map.Clear
Call oMatrix.SetTranslation(oTG.CreateVector(X_Int, Y_Int, Z_Int))
oOcc = oAsmDef.Occurrences.Add(New_Assembly_Name, oMatrix)
oMatrix_1 = oOcc.Transformation
If SharedVariable.Exists("Angles") Then
Angles_Group = SharedVariable("Angles")
MessageBox.Show(Angles_Group(0) & vbCr & Angles_Group(1) & vbCr & Angles_Group(2), "All Angles")
Call oTempMatrix_1.SetToRotation(Angles_Group(0), oTG.CreateVector(1, 0, 0), oTG.CreatePoint(X_Int, Y_Int, Z_Int))
Call oTempMatrix_1.SetToRotation(Angles_Group(1), oTG.CreateVector(0, 1, 0), oTG.CreatePoint(X_Int, Y_Int, Z_Int))
Call oTempMatrix_3.SetToRotation(Angles_Group(2), oTG.CreateVector(0, 0, 1), oTG.CreatePoint(X_Int, Y_Int, Z_Int))
Call oTempMatrix_4.TransformBy(oTempMatrix_1)
Call oTempMatrix_5.TransformBy(oTempMatrix_4)
Call oTempMatrix_6.TransformBy(oTempMatrix_5)
Call oMatrix_1.TransformBy(oTempMatrix_6)
oOcc.Transformation = oMatrix_1
SharedVariable.Remove("Angles")
'oOcc.Visible = False
'oOcc.Grounded = True
'oOcc.ComponentDefinition.Update
Next
'iLogicVb.RunExternalRule("Browser Rename")
iLogicVb.UpdateWhenDone = True
i think i have two errors:
1. the 180 deg is being read as 0.0 radians
2. the matrix transform by method  is not correct, as in I need to check all 3 angles so i need to set to rotation at each angle, then transform by each consecutively?
Thanks In advance.
cencinaNB2ET
Thanks.
I read all of those post but the one where you suggest to change the order of the premultiply function to Z,Y,X.
Im still unsure as to why go through all the trouble of finding the Euler conversion of angles to Quaternion.
Im still struggling with the angles being applied correctly. Basicaly im exracctng aanles crrety but its applied, its reading 180 deg as 0 deg.
