Hi @williamRPTGK. That can actually be a fairly complicated task, because it means exploring Assets and AssetValues of various types to find that specific bit of data about that material. And right now, I'm actually thinking that we may not be able to get that specific bit of information by code. We have access to much of the information you can see in the material editor screen, but apparently not all of it yet. I have a fairly complex iLogic rule I use for exploring all available data pertaining to the 'active' material in a part document, and writing all that data out to a text file (because there is a lot of it). Within the resulting text file, I am not seeing a listing for an AssetValue named "Description", or even an AssetValue with a name containing the word "Description". I will let you play with this yourself, so you can see what I am seeing for yourself. It is currently set to list out info about the Material, Appearance, and Physical aspects of the currently active material in a part.
Here is the code for that:
Sub Main
Dim oPDoc As PartDocument = ThisDoc.Document
Dim oMat As MaterialAsset = oPDoc.ActiveMaterial
oApp = oMat.AppearanceAsset
oPhys = oMat.PhysicalPropertiesAsset
oTxtFile = "C:\Temp\Asset Data.txt"
Dim oSW As System.IO.StreamWriter
oSW = GetCreateTextFile(oTxtFile)
If IsNothing(oSW) Then Exit Sub
Dim AllData As String
AllData = "ALL DATA FOR ACTIVE MATERIAL, ITS APPEARANCE, AND ITS PHYSICAL PROPERTIES"
AllData = AllData & vbCrLf & vbCrLf
AllData = AllData & "<<<< MATERIAL ASSET DATA ONLY >>>>" & vbCrLf
oMatData = GetAssetData(oMat)
AllData = AllData & oMatData & vbCrLf & vbCrLf
AllData = AllData & "<<<< APPEARANCE ASSET DATA ONLY >>>>" & vbCrLf
oAppData = GetAssetData(oApp)
AllData = AllData & oAppData & vbCrLf & vbCrLf
AllData = AllData & "<<<< PHYSICAL PROPERTIES ASSET DATA ONLY >>>>" & vbCrLf
oPhysData = GetAssetData(oPhys)
AllData = AllData & oPhysData
oSW.Write(AllData)
oSW.Close()
ThisDoc.Launch(oTxtFile)
End Sub
Function GetAssetData(oAsset As Asset) As String
Dim oAData As String
oAData = "DispayName = " & oAsset.DisplayName
oAData = oAData & vbCrLf & "Name = " & oAsset.Name
oAData = oAData & vbCrLf & "AssetType.ToString = " & oAsset.AssetType.ToString
oAData = oAData & vbCrLf & "Type.ToString = " & oAsset.Type.ToString
oAData = oAData & vbCrLf & "CategoryName = " & oAsset.CategoryName
oAData = oAData & vbCrLf & "IsReadOnly = " & oAsset.IsReadOnly
oAData = oAData & vbCrLf & "IsUsed = " & oAsset.IsUsed
oAData = oAData & vbCrLf & "HasTexture = " & oAsset.HasTexture
oAData = oAData & vbCrLf & vbTab & "<<< ASSET VALUE DATA >>>"
'For Each oAVal As AssetValue In oAsset
For i As Integer = 1 To oAsset.Count
oReturnedAVData = GetAssetValueData(oAsset.Item(i))
oAData = oAData & vbCrLf & oReturnedAVData
Next
Return oAData
End Function
Function GetAssetValueData(oAV As AssetValue) As String
Dim oAVData As String
oAVData = vbTab & "DispayName = " & oAV.DisplayName
oAVData = oAVData & vbCrLf & vbTab & "Name = " & oAV.Name
oAVData = oAVData & vbCrLf & vbTab & "ValueType.ToString = " & oAV.ValueType.ToString
oAVData = oAVData & vbCrLf & vbTab & "Type.ToString = " & oAV.Type.ToString
oAVData = oAVData & vbCrLf & vbTab & "IsReadOnly = " & oAV.IsReadOnly
'routine to check ValueType then create the appropriate Derived AssetValue Type object
'so we can better extract data from it
Select Case oAV.ValueType
Case kAssetValueTextureType
Dim oTAV As TextureAssetValue = oAV
oAT = oTAV.Value
oAVData = oAVData & vbCrLf & vbTab & "TextureType.ToString = " & oAT.TextureType.ToString
Case kAssetValueTypeBoolean
Dim oBool As BooleanAssetValue = oAV
oAVData = oAVData & vbCrLf & vbTab & "Value = " & oBool.Value
Case kAssetValueTypeChoice
Dim oChoice As ChoiceAssetValue = oAV
oAVData = oAVData & vbCrLf & vbTab & "Value = " & oChoice.Value
Try
Dim oChoiceNames() As String
Dim oChoiceValues() As String
oChoice.GetChoices(oChoiceNames, oChoiceValues)
oAVData = oAVData & vbCrLf & vbTab & vbTab & "Other Possible Choices:"
For i As Integer = 0 To UBound(oChoiceNames)
oAVData = oAVData & vbCrLf & vbTab & vbTab & oChoiceNames(i) & " = " & oChoiceValues(i)
Next
Catch oEx As Exception
Logger.Info("{0}" & "{1}", oEx.Message, oEx.StackTrace)
End Try
Case kAssetValueTypeColor
Dim oColorVal As ColorAssetValue = oAV
oAVData = oAVData & vbCrLf & vbTab & "HasConnectedTexture = " & oColorVal.HasConnectedTexture
oAVData = oAVData & vbCrLf & vbTab & "HasMultipleValues = " & oColorVal.HasMultipleValues
If Not oColorVal.HasMultipleValues Then
oAVData = oAVData & vbCrLf & vbTab & "Color = " & GetColorString(oColorVal.Value)
Else
oColors = oColorVal.Values
For i As Integer = 0 To UBound(oColors)
oAVData = oAVData & vbCrLf & vbTab & "Color = " & GetColorString(oColors(i))
Next
Case kAssetValueTypeFilename
Dim oFileNameVal As FilenameAssetValue = oAV
oAVData = oAVData & vbCrLf & vbTab & "HasMultipleValues = " & oFileNameVal.HasMultipleValues
If Not oFileNameVal.HasMultipleValues Then
oAVData = oAVData & vbCrLf & vbTab & "Value = " & oFileNameVal.Value
Else
oFNames = oFileNameVal.Values
For i As Integer = 0 To UBound(oFNames)
oAVData = oAVData & vbCrLf & vbTab & "Value = " & oFNames(i)
Next
Case kAssetValueTypeFloat
Dim oFloat As FloatAssetValue = oAV
oAVData = oAVData & vbCrLf & vbTab & "HasConnectedTexture = " & oFloat.HasConnectedTexture
oAVData = oAVData & vbCrLf & vbTab & "HasMultipleValues = " & oFloat.HasMultipleValues
oAVData = oAVData & vbCrLf & vbTab & "IsPercentage = " & oFloat.IsPercentage
oAVData = oAVData & vbCrLf & vbTab & "HasLimits = " & oFloat.HasLimits
If oFloat.HasLimits Then
Dim oHasLowLimit, oHasHighLimit As Boolean
Dim oLowLimit, oHighLimit As Double
oFloat.GetLimits(oHasLowLimit, oLowLimit, oHasHighLimit, oHighLimit)
oAVData = oAVData & vbCrLf & vbTab & vbTab & "HasLowLimit = " & oHasLowLimit
If oHasLowLimit Then oAVData = oAVData & vbCrLf & vbTab & vbTab & "LowLimit = " & oLowLimit
oAVData = oAVData & vbCrLf & vbTab & vbTab & "HasHighLimit = " & oHasHighLimit
If oHasHighLimit Then oAVData = oAVData & vbCrLf & vbTab & vbTab & "HighLimit = " & oHighLimit
If Not oFloat.HasMultipleValues Then
oAVData = oAVData & vbCrLf & vbTab & "Value = " & oFloat.Value
Else
oVals = oFloat.Values
For i As Integer = 0 To UBound(oVals)
oAVData = oAVData & vbCrLf & vbTab & "Value = " & oVals(i)
Next
Case kAssetValueTypeInteger
Dim oIntVal As IntegerAssetValue = oAV
oAVData = oAVData & vbCrLf & vbTab & "HasMultipleValues = " & oIntVal.HasMultipleValues
oAVData = oAVData & vbCrLf & vbTab & "HasLimits = " & oIntVal.HasLimits
If oIntVal.HasLimits Then
oIntVal.GetLimits(oHasLowLimit, oLowLimit, oHasHighLimit, oHighLimit)
If Not oIntVal.HasMultipleValues Then
oAVData = oAVData & vbCrLf & vbTab & "Value = " & oIntVal.Value
Else
oVals = oIntVal.Values
Next
Case kAssetValueTypeReference
Dim oRefVal As ReferenceAssetValue = oAV
oAVData = oAVData & vbCrLf & vbTab & "(The 'Value' of a 'ReferenceAssetValue' is another 'Asset'.)"
oAVData = oAVData & vbCrLf & vbTab & "HasMultipleValues = " & oRefVal.HasMultipleValues
Case kAssetValueTypeString
Dim oStVal As StringAssetValue = oAV
oAVData = oAVData & vbCrLf & vbTab & "Value = " & oStVal.Value
Case kAssetValueUnknownType
'do nothing here
End Select
Return oAVData
End Function
Function GetColorString(oColor As Color) As String
GetColorString = oColor.Red & "," & oColor.Green & "," & oColor.Blue & "," & oColor.Opacity
End Function
Function GetCreateTextFile(oFullFileName As String) As System.IO.StreamWriter
Dim oWriter As System.IO.StreamWriter
If Not System.IO.File.Exists(oFullFileName) Then
'file does not exist, so create it
oWriter = System.IO.File.CreateText(oFullFileName)
Else 'file already exists
oAns = MsgBox("The text file already exists." & vbCrLf & _
"Delete it, then recreate it? [Yes] ; Append to it? [No] ; Exit rule? [Cancel]", vbYesNoCancel + vbQuestion, "FILE EXISTS")
If oAns = vbCancel Then
Exit Function
ElseIf oAns = vbYes Then 'delete existing file then recreate it
System.IO.File.Delete(oFullFileName)
ElseIf oAns = vbNo Then 'append to existing file
oWriter = System.IO.File.AppendText(oFullFileName)
Return oWriter
End Function
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you want and have time, I would appreciate your Vote(s) for My IDEAS 💡 or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
