Extracting iProperties
Message 1 of 10
I'm using the Inventor View API in VB.NET, how do I GET/SET the iProperties for a specified file?
(I'm not a programming pro, so dumbing it down might be needed)
David
Replies (9)
Message 2 of 10
> {quote:title=dvandoren wrote:}{quote}
> David
Public Function GetPartNumber(ByVal sFullFileName As String) As String
Dim oApprentice As New Inventor.ApprenticeServerComponent
Dim oDoc As Inventor.ApprenticeServerDocument = Nothing
Dim sPartNumber As String = ""
Try
oDoc = oApprentice.Open(sFullFileName)
sPartNumber = oDoc.PropertySets.Item(3).Item(2).Value.ToString ' Part Number
Catch ex As Exception
End Try
oDoc.Close()
oApprentice.Close()
Return sPartNumber
End Function
Public Function SetPartNumber(ByVal sFullFileName As String, ByVal sPartNumber As String) As Boolean
SetPartNumber = False
Try
With oDoc
With .PropertySets
.Item(3).Item(2).Value = sPartNumber
.FlushToFile()
End With
End With
SetPartNumber = True
End Try
oDoc.Close()
oApprentice.Close()
Return SetPartNumber
End Function
Message 3 of 10
PERFECT!!! Thankyou so much....
I did have to make these changes to get it to work correctly though...
Dim oApprentice As New InventorApprentice.ApprenticeServerComponentClass
Dim oDoc As InventorApprentice.ApprenticeServerDocument = Nothing
Try
End Try
'oDoc.Close()
'oApprentice.Close()
Return sPartNumber
End Function
Try
With oDoc
With .PropertySets
.FlushToFile()
End With
End With
End Try
'oDoc.Close()
End Function
Message 4 of 10
Also, how do your know what Item Index is for which property field?
example, you have Item(3).Item(2) for "part number"
Is there a list defining these items, or do I just need to run through them all myself to figure out whats what?
Message 5 of 10
It is one of ways to get/set Part Number.
Message 6 of 10
Not fully understanding your response. But I see that to set the "Part Number" you use Item(2) in Item(3), hence Item(3).Item(2), what are the items numbers for the other fields? Like "Company Name", "Engineer", etc.
Message 7 of 10
Sorry, I not the professional programmer. I find the necessary indexes in Watch Window. When it is necessary for me.
Message 8 of 10
For what it's worth, I found out a good part of which Items go to which property values. There were 9 that I couldn't figure out what they are for. I think it was for License number of Inventor used, or something like that.
Here they are, they all return as strings....
Title = Item(1).Item(1)
Subject = Item(1).Item(2)
Author = Item(1).Item(3)
Keywords = Item(1).Item(4)
Comments = Item(1).Item(5)
Revision Number = Item(1).Item(7)
Category = Item(2).Item(1)
Manager = Item(2).Item(2)
Company = Item(2).Item(3)
Creation Date = Item(3).Item(1)
Part Number = Item(3).Item(2)
Project = Item(3).Item(3)
Cost Center = Item(3).Item(4)
Checked By = Item(3).Item(5)
Checked Date = Item(3).Item(6)
Eng. Approved By = Item(3).Item(7)
Eng. Approved Date = Item(3).Item(8)
Status = Item(3).Item(9)
Material = Item(3).Item(10)
WEB Link = Item(3).Item(12)
Description = Item(3).Item(14)
Vendor = Item(3).Item(15)
File Subtype = Item(3).Item(17)
Mfg. Approved By = Item(3).Item(19)
Mfg. Approved Date = Item(3).Item(20)
Designer = Item(3).Item(24)
Engineer = Item(3).Item(25)
Authority = Item(3).Item(26)
Stock Number = Item(3).Item(37)
Message 9 of 10
It is better to use names for PropertySets and iProperties rather than numbers.
' Get a reference to the "Design Tracking Properties" PropertySet
Dim oPropSet As PropertySet
Set oPropSet = oPropsets.Item("Design Tracking Properties")
It is safe to use internal names which are the same for any Inventor localization.
Summary Information, {F29F85E0-4FF9-1068-AB91-08002B27B3D9}
Document Summary Information, {D5CDD502-2E9C-101B-9397-08002B2CF9AE}
Design Tracking Properties, {32853F0F-3444-11D1-9E93-0060B03C1CA6}
User Defined Properties, {D5CDD505-2E9C-101B-9397-08002B2CF9AE}
Property.ItemByPropId method provides access to iProperies by named constants
E.g., to get Part Number:
Set oPartNumberProperty = oPropsets.Item("Design Tracking Properties").ItemByPropId(PropertiesForDesignTrackingPropertiesEnum.kPartNumberDesignTrackingProperties)
See also
1) overview “Document Properties” in Programming Help
2) help for PropertiesForDesignTrackingPropertiesEnum Enumeration
3) Autodesk University papers on iProps
Message 10 of 10
Take a look at the paper "Inventor API: Exploring
iProperties and Parameters" that's linked to from this blog posting.  I
believe it answers all of the questions that have been asked here.
