Extract text from sketched symbol
06:41 AM
I am using Inventor 2008 and am trying to extract text from a sketched symbol. I have found the last Revision Block in the database using this code:
Dim oLastRevBox As SketchedSymbol
Dim oSketchedSymb As SketchedSymbol
lNumSymb = oSheet.SketchedSymbols.Count
For i = 1 To lNumSymb
Set oSketchedSymb = oSheet.SketchedSymbols.Item(i)
If oSketchedSymb.Definition.Name = "Rev Block" Then
dInsXPos = oSketchedSymb.Position.X 'find location for insertion of next rev. block
dYPos = oSketchedSymb.Position.Y
dInsYPos = dYPos - 0.254
Set oLastRevBox = oSketchedSymb 'get last rev. block
If oSketchedSymb.Definition.Name = "Rev Block 2" Then
dInsYPos = dYPos - 0.254 * 2
Next
Now that I have the last revision block, I want to extract the text from that sketched symbol:
If oLastRevBox.Definition.Name = "Rev Block" Then
'Get text from oLastRevBox
If oLastRevBox.Definition.Name = "Rev Block 2" Then
The text field are called "Rev Level", "Rev Description", "Rev Date", "Rev By", and "Rev Approved". The fields are the same, but I have two different symbols and the formatting of the text is slightly different.
Tim
Next
Tim
