Extract iProperty information directly from an occurence
shastu
Advisor Advisor
shastu
I know how to extract iProperty information from a file that is open.  What I am wanting to do is be able to capture the iProperty information of a part that is selected in an assembly.  Similar to how I can get the name of the occurrence with:
    Dim oSS As SelectSet
    Set oSS = oDoc.SelectSet
 OccurrenceName= oSS.Item(1).Name
I want to be able to get the Part Number, Stock Number, and Description iProperties of that occurrence
chandra.shekar.g
Autodesk Support
Autodesk Support
@shastu,
Try below VBA code to extract iPorperty information from selected occurrence.
Sub FindiProperties()
    Dim oDoc As AssemblyDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim occ As ComponentOccurrence
    On Error GoTo Exception
    Set occ = oSS.Item(1)
    Dim oReferDoc As Document
    Set oReferDoc = occ.ReferencedDocumentDescriptor.ReferencedDocument
    Dim oPartNo As String
    Dim oStockNo As String
    Dim oDesc As String
    oPartNo = oReferDoc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Expression
    oStockNo = oReferDoc.PropertySets.Item("Design Tracking Properties").Item("Stock Number").Expression
    oDesc = oReferDoc.PropertySets.Item("Design Tracking Properties").Item("Description").Expression
Exception:
    If Err.Number = 13 Then
        MsgBox ("Selected object is not occurrence")
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
shastu
Thanks so much.  I appreciate it greatly.
